Go to Post There is a problem getting girls interested in STEM. Swift, immediate action is required. Continuing to stay the course leads to disaster. - Madison [more]
Unread 27-11-2012, 21:41
DaveFrederick's Avatar
DaveFrederick DaveFrederick is offline
FRC #1895
DaveFrederick is a jewel in the roughDaveFrederick is a jewel in the roughDaveFrederick is a jewel in the rough
Command Based JAVA - Basic Tutorial
I have put together a basic tutorial on how to use the Command Based JAVA approach.
All Feedback is welcome!
Dave Frederick
Mentor, Team 1895
Manassas, VA
File Type: zip df20705_Robotics_JAVA_Practice_board_v09.zip (3.70 MB, 321 views)
Unread 27-11-2012, 21:51
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Command Based JAVA - Basic Tutorial
Yes! I've been waiting for this
Even the last version you posted was one of the best compilations I'd seen.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 27-11-2012, 21:58
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Very well presented and detailed. I will be saving that for future use, if you don't mind.
All opinions are my own.
Unread 27-11-2012, 23:03
For those of us who are curious but don't have the time right now to wade through this, can someone please post an "executive summary" of how this command-based architecture works "under the hood"?
Is it spawning threads in response to events?
Unread 28-11-2012, 01:20
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Here's my understanding of the Command Based robot project. Please feel free to correct me where I'm wrong.
First an overview of the concept:
There are two major classes which are provided that can be extended to contain the majority of the robot specific code, the Subsystem class and the Command class.
Subsystems characterize mechanisms on your robot. So each subsystem (drivetrain, shooter, lift, etc) should extend the Subsystem class and implement any methods for the functionality that subsystem can perform. It abstracts hardware specific funcitons from the rest of the program. So the shooter may have a method setSpeed which takes a parameter in RPMs, but this alone wouldn't be enough to shoot a ball. You will likely need to interact with multiple subsystems to do that.
This is where the Command class comes in. The purpose of the command class is to build more complex sets of functions, a procedure to follow to complete a task. For many commands this requires using methods across a number of subsystems. Groups of commands can be created to complete a number of steps in series or parallel (or a mix of both).
Commands are then linked into operator interfaces (e.g. joystick buttons) or even executed from autonomous modes.
You need to conform somewhat rigidly to the framework for everything to work, but this can have the advantage of helping you organize your thoughts.
How it works:
New instances of Commands are created from events (e.g. button press from operator). These instances are passed to a scheduler which maintains a list of all the active commands. Commands have a number of methods which allow the scheduler to step through their execution (initialize(), execute(), isFinished(), end()).
Part of a command definition provides information as to which Subsystems are required for the particular command. This allows the scheduler to identify conflicting commands, and handle which ones get to execute. Basically whichever command was issued last will execute (if there was a subsystem dependency conflict).
The command based robot project builds on top or the iterative robot project. Methods for each game mode (teleopPeriodic(), autonomousPeriodic()) are called repeatedly (every 20ms - with each driver station update). Calls to the scheduler's run() method are required within the teleop and auto periodic mode methods to allow the scheduler to process outstanding commands.
I found this presentation to be particularly helpful. Start at slide 18.
Once you understand the model it makes building up a fairly complex system quite painless. Throwing together auto mode actions become quite easy, as it simply becomes a new command which calls other existing commands that in many cases have already been tested and proven to work in teleop.
http://team2168.org
Last edited by otherguy : 28-11-2012 at 02:13. Reason: added reference to slide # in linked presentation
Unread 28-11-2012, 09:12
This sounds problematic, unless I'm misunderstanding what was intended.
Unread 28-11-2012, 09:35
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Commands run "in parallel" unless they have a subsystem dependency conflict. Methods are provided by the Command class in order to allow a command to do something if it is "interrupted" by another command that requires the same subsystems.
See http://www.wbrobotics.com/javadoc/ed...l#interrupted()
The Command class also lets you set a command as non-interruptible, but I'm not sure if the scheduler actually honors that or if it is for you to fetch with isInterruptible when making some decisions somewhere.... I've never actually tried it.
Unread 28-11-2012, 09:40
What's the time slice? Does everything run at the same priority?
Unread 28-11-2012, 09:43
AKA: Josh P.
I haven't actually dived into the scheduler to look at it. I'm not sure if it threads or if it is basically splitting the IterativeRobot style command loops between the commands. We've never done anything particularly timing-intensive (yet ) so we never had to look. (that's why I added the quotation marks, hehe)
EDIT: The cookbook says commands are accessed around every 20ms. It doesn't mention anything about priority, though.
Unread 28-11-2012, 10:00
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The command architecture is an interesting concept for robotics, but only because our processors are powerful enough to jump through the extra layers of abstraction without effecting the mechanical performance. I've experimented with sending high-level (marshalled) commands from a prompt to my quadrotor with some success. The architecture is essentially a queue for predicates and closures. The key to success on a larger system is managing compounding and/or non-deterministic behavior that causes the command queue to get gummed up.
As a reviewer's note, the command queue itself should have overriding interrupts -- ways to interrupt the current command with a higher priority command for the same subsystem. End-users under high pressure in an intense match are REALLY good at hitting the wrong button (e.g. to tell an arm to go down when they really wanted it to go up) and then changing their minds in under a few milliseconds.
GitHub
Unread 28-11-2012, 10:11
AKA: Josh P.
As long as your commands require the same subsystem a new command will interrupt the first and go. This lets you run a "default" joystick driving command at all times and interrupt it to do a separate controlled command with the drive subsystem for something like an autoscoring mechanism in a game like '11.
Unread 28-11-2012, 11:29
otherguy's Avatar
sparkE
AKA: James
I was looking at the Scheduler code last night. I didn't see any threads being used for command execution. It's iteratively stepping through a structure which contains all active commands. Sequentially executing them if they aren't complete and removing them if they are.
This process is kicked off by the call to the scheduler's run() method. One pass through the list of active commands per call. That's why it's necessary to place within the respective auto and teleop periodic methods.
The downside to this approach is obviously that if any command takes a significant amount of time to execute, it will block program execution. But this has to be considered for any code written using the Iterative Robot model. Code within each command shouldn't do much more than some logical checks and updating the state of related outputs.
http://team2168.org
Unread 28-11-2012, 11:55
The downside to this approach is obviously that if any command takes a significant amount of time to execute, it will block program execution. ... Code within each command shouldn't do much more than some logical checks and updating the state of related outputs.
That goes to the heart of what I was asking. What you've described sounds like you have to write a state machine if you want time delays and/or wait for events like limit switches etc
Unread 28-11-2012, 11:57
I think you meant abort the first and go? Otherwise, you could get some pretty funky behavior when returning from the interrupt.
Unread 28-11-2012, 12:10
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
A few questions on the command architecture (without reading the paper at the beginning of the document):
-Do subsystems get poked by run() also? Or does run() just poke all of the active commands?
-Is the architecture designed for the subsystems to store the subsystem state, or for the commands to store subsystem state? I would assume the subsystems store their state, but if they don't get poked then the have to wait for a command in progress to do anything (or you have to manually poke them, or start a new thread).
Kettering Motorsports
