Go to Post The bottom line is, what works best for YOUR team is what the best solution is. - EricH [more]
Unread 15-01-2003, 22:24
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
Optical sensors
What is the angle of the cone of detectable light that the sensor emits? Need to know to align the sensors so that we don't have a blind spot.
0N3 1337 PR0G|24MM1N6 N1NJ4
Unread 15-01-2003, 23:54
Kevin Watson's Avatar
La Caņada High School
FRC #2429
You can find that information in the QS18VN6LV data sheet available in the "sensor documentation" section:
http://www.cvhsrobotics.org/resources.htm
-Kevin
Kevin Watson
http://kevin.org
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors great_one411 General Forum 1 15-02-2003 19:54
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
OPTICAL SENSORS??????????????????? NM_programming Technical Discussion 2 13-01-2002 17:41
