Go to Post Patents are an issue of law which, alas, has little to do with engineering or common sense. - Mike Betts [more]
Thread Tools Rating: Thread Rating: 64 votes, 5.00 average. Display Modes
  #91   Spotlight this post!
Unread 28-11-2012, 23:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Tools to have?
I'd recommend a saw such as the Rage Evolution over a horizontal bandsaw. A vertical bandsaw is nice to have though.
Do you have sufficient computers for programming and CAD? Cords and outlet strips?
Do you have a good solid workbench and vise?
Do you have storage? Shelving, container bins, and parts organizers?
Keyway and hex broaches are nice to have, as well as an arbor press.
A 7/8 and a 1 1/8 TCT hole cutter might be good, depending on what bearings you use, and what material you put them in.
I see a lathe as one of the first major investments to make.
  #92   Spotlight this post!
Unread 28-11-2012, 23:37
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Re: Tools to have?
For our team the most used tools we actually have in our shop are our vertical bandsaw and drill presses. Next for us is having access to a good quality mill and lathe which is essential when you get into fabricating drive trains and mechanisms. Our team has been lucky and been able to utilize sponsors equipment so we didn't need to buy our own. Other tools we have and often use are our arbor press, belt/disk sander, heat gun (for bending pvc and plastic), and chop saw.
In the category of tools that we have and don't use is a large harbor freight combination mill/lathe that we rarely use since it is just awkward to work with, instead we end up using our sponsors equipment.
  #93   Spotlight this post!
Unread 28-11-2012, 23:40
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Tools to have?
We purchased a mini benchtop lathe this past season. Our shop also has limited resources since it was setup as a woodshop and not necessarily a metal shop like some of our neighbors have. Band saw (horizontal and vertical), miter saw, table saw, drill press (small and large), large lathe (for wood only), and a small CNC that we use for plastics and sometimes metal but it takes time.
Before dishing out a lot of money for tools and fancy machines your team should sit down and ask what type of capabilities would you like to have and would you use them effectively. It would be a shame to invest a ton of money into tools and machines you won't use. Tools also don't make winning robots or better robots. I know of a few teams who have resources in their highschools one can only dream of and yet they haven't made eliminations in several years. The tools you listed are the same I used on my old team and we produced some very good robots with a few parts outsourced to local shops.
For us the mini lathe was a great investment especially with making roller parts this past season. I'd recommend it but its not a must have.
Good luck!
1058 PVC Pirates 2016 - xxxx
  #94   Spotlight this post!
Unread 29-11-2012, 13:57
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Tools to have?
One of our more recent purchases is heater bar to make cleaner bends with sheet plastics than using a handheld heat gun.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
  #95   Spotlight this post!
Unread 29-11-2012, 14:01
TD78 TD78 is online now
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Re: Tools to have?
Would you have a vendor/part # available for this heater bar? Thanks!
FRC78: 2010-Present
FRC121: 2002-2009
  #96   Spotlight this post!
Unread 29-11-2012, 14:28
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Tools to have?
IMO having a mini lathe/mill [full sized if possible] in the shop as well as a person that can run/teach the tools is amazing.
While we don't have the machine tools in our shop, we have access to them at a sponsor company off site, and using them we were able to expand what we able to do ten fold.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
  #97   Spotlight this post!
Unread 29-11-2012, 15:36
FRC #1836 (MilkenKnights)
Re: Tools to have?
Usually you don't need a heater bar. 1/16" polycarb bends on a brake.
  #98   Spotlight this post!
Unread 29-11-2012, 15:56
Phyrxes's Avatar
AKA: Dave Button
Re: Tools to have?
The heater bar is used mostly for thicker thermoplastics that wouldn't bend cleanly in the brake when cold, like 1/8 or 1/4 inch hdpe or nylon.
Dave Button
Wakefield School
The Plains, VA
  #99   Spotlight this post!
Unread 29-11-2012, 18:49
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Re: Tools to have?
Personally, I have trouble thinking of what to even do with a lathe..
Could you guys give me some ideas? The only thing that comes to mind are rollers for a conveyor belt.
I'm by far not the best mechanical member of our team, so I may not have the mechanical imagination that some of you do, but I'd like to hear some examples of what a lathe has enabled you to do.
  #100   Spotlight this post!
Unread 29-11-2012, 19:04
Phyrxes's Avatar
AKA: Dave Button
Re: Tools to have?
http://www.amazon.com/ft-Strip-Heate...c+sheet+bender
We ordered through amazon instead of the manufacturer.
Common lathe usage is to turn down stock to a smaller diameter or to turn down hex shaft to round stock so that "normal" bearings can be used. You also have the option to turn your own pulleys or wheels especially if you also have access to a press and broach.
Dave Button
Wakefield School
The Plains, VA
  #101   Spotlight this post!
Unread 29-11-2012, 19:40
Mk.32's Avatar
AKA: Mark
Re: Tools to have?
For the lathe that we used, we have done spacers [about 40?], shafts [wcd/gearboxes dozens of these], pulleys/rollers, hubs for wheels, custom minibot wheels, custom wheels in general etc.
Pretty much anything round goes into the lathe. You will find more uses as you go along, I am not saying machine tools are necessary but they can help a lot. For example I don't see any other way to make a shaft true then with a lathe.
  #102   Spotlight this post!
Unread 29-11-2012, 20:37
Re: Tools to have?
In addition hubs, gears, and pulleys. All your round parts will need a lathe because it is very hard(almost impossible to make them accurately) to make them without one.
  #103   Spotlight this post!
Unread 02-12-2012, 01:04
ksafin's Avatar
AKA: Kirill Safin
Re: Tools to have?
Budget Aside, I wanted to get your input on my ideas about a few new tools to buy..
Here's a list:
Rolling Cabinet 30" $150 http://www.harborfreight.com/11-draw...fQ%3D%3D%0D%0A
16" Variable Speed Scroll Saw $64.99; $59.99 with coupon. http://www.harborfreight.com/16-inch...saw-93012.html
Combination 4" x 36" Belt / 6" Disc Sander $79.99 http://www.harborfreight.com/4-inch-...der-97181.html
3-1/2 HP 14" Industrial Cut-off saw $99.99 http://www.harborfreight.com/3-12-hp...saw-68104.html
18 V Cordless Jigsaw $29.99 http://www.harborfreight.com/power-t...saw-68242.html
1 ton Arbor Press $47.99 http://www.harborfreight.com/1-ton-a...ress-3552.html
Horizontal/Vertical Metal-Cutting bandsaw $249.99 http://www.harborfreight.com/horizon...saw-93762.html
115 Piece High speed drill bit set $35.99 http://www.harborfreight.com/115-pie...index-528.html
Automatic Center Punch $2.99 http://www.harborfreight.com/spring-...punch-621.html
130 Piece Tool Kit with Case $34.99 http://www.harborfreight.com/130-pie...ase-68998.html
6" digital Caliper w/ Fractional & metric readings $24.99 http://www.harborfreight.com/6-digit...ngs-68304.html
10 Piece Diamond Grit File Set $7.99 http://www.harborfreight.com/10-pc-d...sets-6989.html
7" Wire Stripper w/ cutter $4.99 http://www.harborfreight.com/7-inch-...ter-98410.html
Ratcheting Crimping Tool $9.99 http://www.harborfreight.com/ratchet...ool-97420.html
Soldering Station $19.96 http://www.amazon.com/Soldering-Stat...4412642&sr=1-2
60 Piece Alloy Steel Tap/Die Set Metric & SAE Fractional $39.99 http://www.harborfreight.com/60-piec...set-35407.html
10 Rolls 3/4" x 60 ft Electrical Tape $4.99 http://www.harborfreight.com/interes...tape-6047.html
12 in Ratchet Bar/Clamp Spreader $3.49 http://www.harborfreight.com/interes...der-46807.html
5 gallon wet/dry vacuum blower $44.99 http://www.harborfreight.com/garage-...wer-94282.html
3 Piece Folding Hex Key Set $6.99 http://www.harborfreight.com/hand-to...eys-94905.html
22 Piece SAE & Metric Combination Wrench Set $17.99 http://www.harborfreight.com/hand-to...set-47467.html
Multi-purpose Workbench with Lighting & Outlets $99.99 http://www.harborfreight.com/multipu...let-99681.html
Workbench w/ 4 drawers, 60" hardwood $159.99 http://www.harborfreight.com/60-inch...nch-93454.html
7" x 12" Precision Mini-Lathe $699.99 http://www.harborfreight.com/7-inch-...the-93799.html
16 Speed Heavy Duty Floor Drill Press $279.99 http://www.harborfreight.com/garage-...ess-43378.html
  #104   Spotlight this post!
Unread 02-12-2012, 14:15
Mk.32's Avatar
AKA: Mark
Re: Tools to have?
The amount of harbor freight I see on that list somewhat worries me... Personally I would avoid HF for any tool that need to be powered, but there are people that have gotten good deals with Hf.
  #105   Spotlight this post!
Unread 02-12-2012, 17:07
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Re: Tools to have?
Here's a list:
When would your team use these tools? If you can't think of a time that you think you would use these tools most likely they wouldn't end up getting used. It seems to be that if you are building your robot out of metal components that the Scroll saw and Jigsaw might go unused. But if you think that these would be used in the prototyping phase then they would be good purchases.
I think that while this is a good list of tools that your team may use i would recommend considering what tools you used last season or wished that you many have.
The list above are some on the tools I wonder if you would actually use. IMO having a full set of taps and dies aren't needed. There are very few times in FIRST where i have even considered using a die to be necessary. And while in some rare cases it might be useful to have a full tap set why not buy multiples of the few sizes that your team uses. If you only use 1/4 20 hardware the other sized taps would be unnecessary.
I would say the same thing about the multi-tool and allen wrench sets if you think that your team may use all these different tools than this would not be a bad purchase, but i think you could better spend your money having more than one of the sizes that you use most often. Nothing is worse than losing the one needed wrench size, and having to make due.
Lastly the work benches, I think that your team could built much cheaper ones that would better fit your work space. Buying some 2x4's and making some tables could be a fun team activity allowing some newer members to get acquainted to your teams tools and or shop.
