| Thread Tools |
Rating:
Display Modes |
Resetting the C-Rio
How do you do a physical reset of the crio using the reset button
Re: Resetting the C-Rio
Just to reboot the cRIO, push the reset button once and let go.
The reset button can also be used to boot the 4-slot cRIO into Safe Mode, by holding the reset button down a while. |
Will that clear its memory and everything
No.
The reset won't clear memory. You have to use the FRC cRIO Imaging Tool to accomplish that. In unusual cases,
Darn i was thinking it might fix the problem i detailed at http://www.chiefdelphi.com/forums/sh...d.php?t=109741
You have to get the laptop and cRIO recognizing each other.
Use the FRC cRIO Imaging Tool just to see if it can identify the cRIO. That doesn't care if the IPs of the two devices are compatible or not. It'll see the cRIO if the connection is working at all. Try connecting various ways, e.g., direct Ethernet like you tried, or Ethernet through a switch. Don't bother with wireless though. Last edited by Mark McLeod : 29-11-2012 at 21:32. |
#7
I've had two different 4-slot cRIOs where the network port has gone completely dead, with no link or activity lights even in safe mode. Neither MAX or the Imaging Tool will find them either. And I'm aware of other teams that have experienced the same problem.
The only solution both times has been to RMA the device back to NI for replacement. |
#8
Our switch isnt working could i possibly boot it in safe mode and reimage it that way
Do you have a manual for the 8-slot crio you could send me Our only battery is also being used and we have lost the charger is their a way to make sure the battery has enough charge Last edited by inkspell4 : 29-11-2012 at 21:17. |
#9
If you have a low battery, that can be the cause of your connection problem.
You can test the battery under load by powering up the cRIO, then using a multi-meter on the Power Distribution Panel input power lugs to see that you're getting enough voltage. Assuming it's only powering the cRIO (not any motors), then it doesn't have to read 12v, but shouldn't read less than 8v (and that's really too low). Don't attempt to re-image if your battery isn't above 10v to be on the safe side. If the power dips too low during imaging, then you'll leave the cRIO in a funky state and have to build the cRIO up from scratch, and without reliable power, it'll never get done. What kind of manual are you looking for? If you're just looking for instructions on re-formatting the cRIO, then I can write those up for you. Getting Started with the 2012 Control System is a good general FRC document to start with. cRIO-9074_OperatingInstr.pdf are the general cRIO I operating instructions. You probably don't want to pay too much attention to the standard generic cRIO operating instructions. Some of the information applies, but other directions it gives isn't what you should be doing with our special hardware/software setup of the cRIO for FRC. For instance, the NI standard tool, MAX, probably isn't what you should be using without better expert guidance. Last edited by Mark McLeod : 29-11-2012 at 21:58. |
#10
Ok then i dont think that it is a problem with the battery what else do you think that could cause the problem
#11
Would it possibly help if I used the ip configuration switch to reset the networm
