Go to Post "Splet" is the sound a frog makes when it hits pavement at 187 feet per second. Don't ask me how I know. - dlavery [more]
Unread 29-11-2012, 16:26
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Resetting the C-Rio
How do you do a physical reset of the crio using the reset button
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 29-11-2012, 17:49
Re: Resetting the C-Rio
Just to reboot the cRIO, push the reset button once and let go.
The reset button can also be used to boot the 4-slot cRIO into Safe Mode, by holding the reset button down a while.
Unread 29-11-2012, 17:50
inkspell4's Avatar
Will that clear its memory and everything
Unread 29-11-2012, 17:59
No.
The reset won't clear memory. You have to use the FRC cRIO Imaging Tool to accomplish that.
In unusual cases,
  1. The 4-slot reset can be used to boot the cRIO into Safe Mode, (the 8-slot uses the Safe Mode DIP switch)
  2. Then (while in Safe Mode) the Imaging Tool is used to wipe and reformat the cRIO.
  3. Afterwards, and out of Safe Mode, the FRC image needs to be installed by the Imaging tool,
  4. Then the user code reloaded.
Unread 29-11-2012, 18:06
inkspell4's Avatar
Darn i was thinking it might fix the problem i detailed at http://www.chiefdelphi.com/forums/sh...d.php?t=109741
Unread 29-11-2012, 18:29
You have to get the laptop and cRIO recognizing each other.
Use the FRC cRIO Imaging Tool just to see if it can identify the cRIO.
That doesn't care if the IPs of the two devices are compatible or not. It'll see the cRIO if the connection is working at all.
Try connecting various ways, e.g., direct Ethernet like you tried, or Ethernet through a switch. Don't bother with wireless though.
Unread 29-11-2012, 19:12
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I've had two different 4-slot cRIOs where the network port has gone completely dead, with no link or activity lights even in safe mode. Neither MAX or the Imaging Tool will find them either. And I'm aware of other teams that have experienced the same problem.
The only solution both times has been to RMA the device back to NI for replacement.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 29-11-2012, 21:11
inkspell4's Avatar
Our switch isnt working could i possibly boot it in safe mode and reimage it that way
Do you have a manual for the 8-slot crio you could send me
Our only battery is also being used and we have lost the charger is their a way to make sure the battery has enough charge
Unread 29-11-2012, 21:43
If you have a low battery, that can be the cause of your connection problem.
You can test the battery under load by powering up the cRIO, then using a multi-meter on the Power Distribution Panel input power lugs to see that you're getting enough voltage. Assuming it's only powering the cRIO (not any motors), then it doesn't have to read 12v, but shouldn't read less than 8v (and that's really too low).
Don't attempt to re-image if your battery isn't above 10v to be on the safe side. If the power dips too low during imaging, then you'll leave the cRIO in a funky state and have to build the cRIO up from scratch, and without reliable power, it'll never get done.
What kind of manual are you looking for?
If you're just looking for instructions on re-formatting the cRIO, then I can write those up for you.
Getting Started with the 2012 Control System is a good general FRC document to start with.
cRIO-9074_OperatingInstr.pdf are the general cRIO I operating instructions.
You probably don't want to pay too much attention to the standard generic cRIO operating instructions. Some of the information applies, but other directions it gives isn't what you should be doing with our special hardware/software setup of the cRIO for FRC. For instance, the NI standard tool, MAX, probably isn't what you should be using without better expert guidance.
Unread 29-11-2012, 21:47
inkspell4's Avatar
Ok then i dont think that it is a problem with the battery what else do you think that could cause the problem
Unread 30-11-2012, 18:01
inkspell4's Avatar
Would it possibly help if I used the ip configuration switch to reset the networm
