Re: Drive Motors turning off then losing signal
From our teams experience using jaguars is that they can sometimes fail and cause intermittent problems like the ones you describe. Also, make sure that you're motors aren't running in opposite directions and that your gearbox is working well. I don't usually use labview, but I thought that it was unnecessary to use a watchdog and that could be causing the problem. You might want to try running them motors without them connected to the gearbox. If that doesn't work, I'd just try creating a new robot project and not adding the watchdog. Also, double check that all your parts are well connected, and that the joystick is on the same port in the driver station ans in LabView.
There is absolutely no reason to reimage the cRIO in this circumstance. It is a complete waste of time. And I didn't look too closely at your code, but I doubt that is the issue.
1. Verify that your battery is charged. As the motors draw current, the voltage of the battery drops. If it drops too low, the motor controllers may stop working. 2. Verify that the motors are not fighting one another and that they are not drawing too much current because of binding or because of the gear ratio. Greg McKaskle |
Check your digital sidecar wiring, it was a source of problems for us.
Ah, yes.
Greg McKaskle |
Thanks for the answers!
I don't think it is the motors moving against each other, because they WILL spin, but they lose signal. Hard to explain but we definantly made sure they were not moving against each other. The gearbox is fine because again, they do work, but it's only in one direction. I'm thinking it is an electrical issue. As per reformatting the cRIO, we didn't really know what to do so that was one of our last options. And we've rewrote the code several times with and without the watchdog. What exactly do you mean by supply power to the digital breakout? This sounds like it could be the problem. Is this a module on the cRIO or is it on the digital sidecar itself. Noob question, I know . It's been a while.Thanks for the answers though! |
It'd be the sidecar itself. Down at the bottom (Where PWM port 1 is) there should be a Wago connector that carries 12v from the Power Distribution Board.
#7
I'm almost postive we have that plugged in. It might not be the right voltage though, I'll check on monday.
#8
Grab a spare Jag from somewhere, power it, and plug in a PWM. If it functions properly, you've got 2 bad jags. We had the same problem not long ago, and thought we were going crazy because we replaced a bad jag with another bad jag.
3rd times the charm. You can easily check if the motors are fighting each other by disconnecting one of the PWMs and running the other. |
#9
The symptoms point perfectly to the Digital Sidecar not receiving battery power. Make sure you've got its power input wired to a 20-amp circuit on the Power Distribution Board.
#10
Yeah, sorry for not coming back and answering! It turns out we did not have the power coming from the right source! Found a handy wiring guide that I cannot believe we did not have before.
Thanks guys! ![]() |
