Go to Post As a team leader if I do not INSPIRE I have failed, and I do not like to fail. - Mike Martus [more]
Unread 15-11-2012, 20:36
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
Programming for sonar with MaxRobotix Sensor
Hi, we are trying to get a reading from our MaxRobotix Sensor that we have plugged into pin 1 of the Analog input. We are using java (NetBeans) for programming. Some of our code:
Declaring variable:
public static final Button ultrasonicSensor = new AnalogIOButton(1);
And inside out Autonomous section, we simply print out ultrasonicSensor.get();
It would be greatly appreciated if someone could help us get a reading from our sensor so that we can work with it
Unread 16-11-2012, 23:05
thephpdev's Avatar
thephpdev thephpdev is offline
AKA: Josh Larson
FRC #2502 (Talon Robotics)
thephpdev is an unknown quantity at this point
Re: Programming for sonar with MaxRobotix Sensor
You can get a reading from a sensor by getting the voltage output by the sensor. Which can be done like this:
private AnalogChannel ultrasonic = new AnalogChannel(1);
private double voltage = ultrasonic.getVoltage();
Unread 25-11-2012, 01:21
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
To get inches from the sensor I THINK you need to multiply the output voltage by 100. again I'm not positive. This is info I carried over from Labview. I see no reason it would be different.
Unread 02-12-2012, 15:11
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
If you're using the maxbotix LV-MaxSonar-EZ sensor, there's a good guide here:
http://www.maxbotix.com/articles/016.htm
This page includes details on converting the measured analog value to a distance in inches.
http://team2168.org
Unread 02-12-2012, 18:06
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Hey,
So we used an unltrasonic sensor on two of the robots I worked on, and both times we used the .get() method, it returns integers that correspond to distance (in an arbitrary unit). Should work fine either way.
As for your problem, we noticed that we got strange issues when we had something connected to both analog 1 and 2, we're still not sure why, but if both were connected one or both wouldn't work (I don't remember the exact symptoms). We found this problem when working with a gyro, so it could have been specific to a gyroscope, but it might not be. Regardless, you could try switching the port you are using.
Also, I just realized you are using this as a AnalogIOButton object? Is this a sensor on the driver station or on the robot? If this sensor is plugged into the cRio Analog Card (which is what I had assumed, and the above information is referring to), then I believe this should be an AnalogChannel Object. If not, what is the purpose of the sensor? and what is it's use in autonomous mode, because driver station inputs are disregarded in autonomous?
www.sharkattack744.com
Unread 02-12-2012, 19:09
DonRotolo's Avatar
Back to humble
FRC #0832
Isn't Analog1 used for battery voltage?
Unread 02-12-2012, 19:16
Analog input 8 is disabled/enabled by the breakout jumper for the battery feed.
The Analog input pins closest to the jumper.
Unread 02-12-2012, 19:25
DonRotolo's Avatar
Back to humble
FRC #0832
Oh. I knew it was one of them at the end...
