Go to Post FIRST people are so cool. - Karibou [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
  #31   Spotlight this post!
Unread 26-12-2001, 23:52
EStokely's Avatar
EStokely EStokely is offline
AKA: Eric Stokely
FRC #0360 (Revolution)
EStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond repute
OK. I had posted something like this somewhere but I like it and it is probably it javascript:smilie('')
*2 vs 2
*Robots start on opposite side from thier controllers.
*There is a 3 foot (or so) wall cutting the field in half the long way. Robots are not allowed to cross this wall.
* THere is a shelf (I saw written here and I liked the idea) running along the top of the wall.
*There are 3 different foam pieces that coorespond to the FIRST logo.
*Teams stack the pieces on the wall to create a correct logo (in the right order) while being able to steal the opponants foam pieces.
*A movable something that will multiply score depending on whos side it is on (OK I haven't thought this part out since the BOM release)
That all being said....
I like the idea of the teams standing on all four sides, unable to run behind each other during play and give advice. Makes planning more important.
Getting closer....
Eric Stokely
Eric Stokely
Team 360 The Revolution, past mentor of 258 The Sea Dawgs
Experience is what you get when you don't get what you want.
  #32   Spotlight this post!
Unread 27-12-2001, 15:33
Mike Carron Mike Carron is offline
#0343 (Metal In Motion)
Mike Carron is an unknown quantity at this point
Exclamation another idea for the game
OK Here's my take on the game for 2002. Let's see how close it is. The field will be setup about the way it was last year, except the center will be a ramp like in 1999. The format for 2002 is two on two with two stretchers. Each alliance HAS to put one of their alliance robots on the stretcher. They must move the robot/stretcher combination over a ramp to the other side to get ten points. Remember how hard that was last year. And guess what two teams will be trying to do this over ONE ramp that is 48" wide. Of course a robot can come off of the stretcher if he/she wants to, but then the other team will get 5 points for the unoccupied stretcher and you will only get 5 points (assuming you are in the end-zone) for just the robot. As for scoring, there will be only black balls worth five points each and ONE large 30" ball that can be put on top of either a blue or red goal -depending on your alliance color. That will get that alliance score x2. Get that-ONE ball two alliances! Oh buy the way, the final scoring will be... winning alliance gets their score plus the losing alliance score and the losing alliance gets the winning alliance score. Talk about keeping it close. That will really make you help the other alliance, just think if they got zero points then all the teams tie!!!! They would get the winning score and the winners get theirs plus zero!!. Anyway, chew on that for awhile. I can't wait until next Saturday wooohoooo. Mike Carron
Tempest Fugit
  #33   Spotlight this post!
Unread 27-12-2001, 16:06
Brian Card's Avatar
Brian Card Brian Card is offline
Brian Card is an unknown quantity at this point
Mike,
How about having the exact same game as last year except played in reverse, i.e. both goals start balanced on the bridge full of black balls, each with two large balls on top. The objective: return both large balls to the endzone, along with the black balls and each black ball returned to the human players receive some hefty bonus points. Then, all robots must return to their original starting position with the brige tipped toward the currently competing teams. In other words, the game ends exactly how the game began last year. That would be interesting, however, the BOM doesn't seem to support this theory.
Brian Card
Team 343
  #34   Spotlight this post!
Unread 05-01-2002, 05:24
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
(Admiring Stokely's idea about the FIRST logo)
All Right, here's the winning (and probably last) submission:
The most important part about this year's game is that it will be played 2 v 2 but there will be one challenge that will multiply everyone's score, and the challenge will be such that it will require participation by at least one robot from each alliance.
For everything else, I think I pretty much agree with Joe (if I remember his post correctly):
There will be a rolling goal: From the bottom to top, wheels, then plywood, then a section raised by the 12" nipples, then more plywood. The top section of plywood will have a cutout hole, and the 3" PVC will be place through that hole so it rests on the lower plywood.
The scoring object will be torroidal (sp?) and will be placed over the 3" pvc, like horseshoes.
The big hole in this is the 1" PVC. No idea where that will go. Perhaps the 3" PVC will be surrounded by vertical sections of 1" PVC, arranged like last year's goal, as a spoiler.
Good luck to everyone!
Eric.
  #35   Spotlight this post!
Unread 05-01-2002, 18:54
E. The Kidd's Avatar
E. The Kidd E. The Kidd is offline
Member of the Red Army
E. The Kidd is on a distinguished road
Send a message via AIM to E. The Kidd
well who are the two winners?
  #36   Spotlight this post!
Unread 07-01-2002, 16:53
Anton Abaya's Avatar
Anton Abaya Anton Abaya is offline
None #0419 (Rambots)
Anton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura about
Send a message via ICQ to Anton Abaya Send a message via AIM to Anton Abaya
I WIN!
I WIN I WIN! I got everything right!
-antonsmart
ps. http://www.creighton.edu/~pwnovak/whee/Weeee.swf
  #37   Spotlight this post!
Unread 07-01-2002, 18:09
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
actually, you didn't get everything right. None of the poles are black (they looked silver or grey).
Zan Hecht
  #38   Spotlight this post!
Unread 07-01-2002, 18:30
ACK! YOU'RE RIGHT!
DARNIT! Eh... nobody's perfect.
90% accuracy though
-anton
  #39   Spotlight this post!
Unread 07-01-2002, 19:25
EddieMcD EddieMcD is offline
EddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud of
It's really sad when the winning guess has nothing to do with the actual game!
So, does he actually win?
  #40   Spotlight this post!
Unread 08-01-2002, 16:41
sad but truuuuueeee....mwhahahahh.
-anton
  #41   Spotlight this post!
Unread 31-12-2007, 17:51
11Mort11's Avatar
11Mort11 11Mort11 is offline
AKA: Alex Joss
FRC #0011 (MORT)
11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold
Send a message via AIM to 11Mort11
Re: 2002 game prediction contest!!!
wrong thread
  #42   Spotlight this post!
Unread 31-12-2007, 18:18
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Originally Posted by 11Mort11 View Post
wrong thread
Well done Alex. That might be the king of bumps!
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
California Robot Game 2002 Ken Leung Western Region Robotics Forum 0 09-09-2002 20:16
what did you think of the 2002 game Rob Colatutto Regional Competitions 21 08-09-2002 19:20
PUSH to Simplify the Game for 2002 ***Attention FIRST *** archiver 2001 37 24-06-2002 03:45
How about those prediction of this year's game? archiver 2001 7 23-06-2002 22:22
