| Thread Tools |
Rating:
Display Modes |
#106
Re: Tools to have?
I don't believe this stuff has been mentioned, but how's your electrical tools looking? A good soldering iron, pair of sharp diagonal cutters, auto strippers, and preferably an ideal crimper will alleviate most of your electrical worries in season.
As well, if you don't have a budget set aside for this, make sure before you go buying stuff you might use, that you replenish stock of materials you did use and probably will use. |
#107
Re: Tools to have?
Scroll Saw: We would really like to get one in order to cut polycarbonate and various other plastics and thin sheets into shapes that aren't accommodated by straight-line cutting saws. Quote:
As far as Allen wrench sets, we mostly use 5/32 and 1/4 but I haven't really seen a place where we can just buy a load of 5/32 allen wrenches or something. So sets made sense.[/quote] Quote:
![]() Yes, replenishing metals & other materials we'll use comes before our tools budget. |
#108
Re: Tools to have?
In fact, we gave out bundles of them wrapped in a bow as alliance gifts last year (our PR lead came up with this ) |
#109
Re: Tools to have?
Our team owns a Band Saw (min. throat), a Drill Press(Machinist Mentor to Teach) a Mini lathe, a cut off saw for wood but can cut Aluminum, a tap set, Bearing Press, Battery Chargers, Battery Tester, Soldering gun, multi- meters, crimpers, rivet guns and plenty of hand tools. I feel we need a Scale that will weigh a complete robot, broaches, and better storage.
We also have plenty of hardware and Aluminum. |
#110
Re: Tools to have?
One of my favorite tools in a set of ball end hex bits. Ih you have a drill with a clutch it makes assembly really quick.
#111
Re: Tools to have?
I can guarantee you that the taps and drill bits you've linked are complete garbage. You simply cannot purchase quality cutting tools in that quantity for that price.
I would recommend buying taps as needed (and high quality ones...we're not talking $10 a piece either, more like $2-3). If you want to get the all in one drill set, at least buy 5-10 quality individual drills of common sizes (#7, #21, #29, F, etc). Those 4 will probably be your most commonly used drill bits if you use #8-32, #10-32, and 1/4-20 hardware. |
#112
Prepare a set-aside for replacement drill bits and taps. Novices have incidents that are tough on small tools. A multitude of 7/16" open end/box end wrenches is a must.
If you are looking for power tools, I'd recommend a machine that will allow precision drilling/boring for precise located hole patterns if you can utilize CAD models for robot design. A lathe would be nice to have (we use 1940's South Bend lathe in a mentor's basement for small cylindrical work) if you suspect that you cannot design using off-the-shelf shafts, bearings and gears/sprockets. Another use for a lathe is for modifying readily available parts that you may want to change diameters on or add or snap ring grooves to. Our team has been adding tools as the years progress based on a targeted need from our mentors. It all depends on the expertise available for instruction and the past need for abilities. Don't purchase machines just because resources are available. Engineering is about doing what you can with the resources available. Try to maximize your efficiency. Good luck, and may your resources remain solid and grow over the years. |
#113
Re: Tools to have?
In the past, I've bought a 45-piece (I think) set of metric and Imperial taps, dies and handles on sale for about $30 (CAD)—but those are just for insurance on the day when you absolutely need an oddball size during a late-night work session, and for the cheap but adequate handles. (Canadian Tire's Boxing Day and Fathers' Day sales are good for amassing a collection of FRC-grade tools cheaply.) Buy high-quality machine-rated straight-flute thread-cutting taps, in each of the common sizes. Unless you know what you're doing, don't use them under power. But take advantage of their strength and precision to avoid worrying about breaking them. (It's not the broken tap that's the problem, it's the part you just ruined on the last machining step.) Last edited by Tristan Lall : 03-12-2012 at 03:20. Reason: I think it was actually a 45-piece set. (It came in a big metal case.) |
#114
Re: Tools to have?
If you are on a low budget and are allowed to purchase items online, check out ebay and craigslist. We found some great deals on Craftsman tools on craigslist and plenty of older drillpresses and bandsaws on there as well. Occasionally, you'll find a solid and well priced lathe or mill, but you have to jump on those pretty quick. Tool chests can also be found from Snap-on and Crafstman for around $300-500 on CL. Don't think you need to purchase everything in one season for your build space. Make a few compromises now for what you'll have in-house so that you may purchase more high quality items and substitute things like mills/lathes by contacting local machine shops. You can always purchase more items as you go along and raise more money. |
#115
Re: Tools to have?
Sadly Craftsman is not all that much higher on the totem pole than Harbor Freight anymore.
#116
Re: Tools to have?
Hmm a lot of the items on sale we found were quite old. Many people were selling tool chests and cabinets as is with many hand tools inside. I would hope the older stuff was still higher quality.
#117
Re: Tools to have?
They don't make them like they used to. ![]() |
#118
Re: Tools to have?
Some of the most reliable equipment we have is from the original outfitting of our school's shop in the early 70s.
Depending on your relationship with the school you may be able to get first shot at equipment that is being replaced. |
#119
Re: Tools to have?
Harbor freight can be useful for cheap non-powered tools as long as you take it all with a grain of salt.
I've used high-torque Allen keys for years and have yet to strip out the hex key on any of them. |
#120
Re: Tools to have?
So, I don't really understand what's wrong with HF tools..
We've had a few HF power tools for a few months and there's been nothing wrong with them. The drill press drills, the miter saw saws, and the grinder grinds. They never broke, had any safety issues, or otherwise been a concern. While they probably could work smoother (the miter saw just has a weird feel to me, after using a Ryobi last year), they work fine and we don't have any major issues with them. |
