Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Unread 03-12-2012, 15:59
Jay Meldrum's Avatar
Jay Meldrum Jay Meldrum is offline
FRC #0067 (H.O.T.)
Jay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud of
Re: Behind The Design 2012
The graph on the top left of page 8... I assume this is an open-loop test at 12 volts. The text says the team chose the 8000 rpm free speed, which would be the 1:2 gear ratio according to the graph. The text also says 4000 rpm was used for shooting from the key. Does anyone know what control algorithm 67 used for shooter speed?
Ether: We used a PID. The input was the rate of a light sensor (3 division flywheel was on the shaft of shooter). We had 3 preset shoot speeds based on different locations on the field: top of key, bottom of key, hail mary. We also manually modified those speeds during the match depending on ball "squishiness".
2012-2015 - FRC 67 - Programming/Controls Lead Mentor
2003-2005 - FRC 857 - Driver
Check us out at http://www.hotteam67.org
Previous year design docs, programming tutorials, and more!
