Go to Post Just because we don't cheer, doesn't mean we don't have fun. ;) - JVN [more]
Unread 13-01-2003, 00:30
Umm Errr...
Speed controller fan replacement
Is it legal to swap out the fans on the speed controllers? These fans are absolutely pathetic. Not to mention that there are no heatsinks on the fets( or whatever they are). I come from an overclocking background and these fans are absolutely worthless. I want some YStechs
1139 Alumni
Unread 13-01-2003, 00:36
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
Yes it is legal to swap them out, but I don't think you can just buy the fans.
Unread 13-01-2003, 00:38
Umm Errr...
does this count as "custom electronics" am i limited to the fans from digi-key and the other place?
1139 Alumni
Unread 13-01-2003, 04:58
Electrical Engineer
Rookie Year: 1995
Rick,
I've been doing FIRST for 9 years now and have used the IF speed controllers since they first came out.
IMHO, you will overheat your motors or trip circuit breakers way before you have problems with the SC.
My advice is that you have bigger problems to worry about and to not fix things that are not broken.
Mike Betts
As easy as 355/113...
Unread 13-01-2003, 06:42
Matt Reiland's Avatar
'The' drive behind the drive
You can buy just the fans from IFI which according to the update would not be added to the $3500 since it is from IFI
I would however agree that you will have a heck of a time getting one of them to fail with the loads that we are putting on them, Battlebots users are starting to use them with huge banks (100+ batteries) of NiCads that dump insane current loads into them and the failure rate is very low.
Unread 13-01-2003, 08:48
Umm Errr...
true. u guys r plolly right.
1139 Alumni
Unread 13-01-2003, 09:22
FRC Key Volunteer Trainer
AKA: CrazyNate
Actually, according to rule K5(as amended in team update #2), anything purchased from IFI does not count toward your $200 custom electronics limit, but it does count toward your $3500...
Nate Smith
nsmith@smythsoft.com
Unread 15-01-2003, 10:52
n[ate]vw's Avatar
n[ate]vw n[ate]vw is offline
#0933 (Adler Attack)
n[ate]vw is an unknown quantity at this point
Send a message via AIM to n[ate]vw
The only problem with the fans/Victors that our team had last year was contamination. If metal shavings or dust got in them, they would overheat and destroy the Victor. Otherwise, the fans work fine if you are making sure they stay clean.
Adler Attack #933 -- Trigos
Unread 15-01-2003, 11:20
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Yeah, you really don't want metal shavings in ANYTHING. Especially motors and the transmissions. The only problem I have with the fans is that is you catch them just right, they chip your finger nail.
Unread 15-01-2003, 12:15
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
I just had this conversation with someone last night.
The only time we have ever had a problem with anything overheating was when we played our finals matches on Einstein last year. (For those of you who don't know, the Einstein division field was outside last year.)
Heat + humidity + running a lot of matches = overheating.
To solve that problem, we sprayed cold spray on our electronics after every match. I don't think anyone will have to worry about overheating because of weather this year (all of the fields are indoors!)
Other than that, we've never had a problem with overheating, even during other finals matches. The weather was the only thing that affected us last year ::shrug:: You should be fine.
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 15-01-2003, 19:15
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
We had one catch fire once...but never could figure out why...we figured some kinda shavings got in it.
Wouldn't changing the fan count as modifing the IF electronics and be against the rules?
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 16-01-2003, 08:46
People,
Speed controllers have always been on the "Do Not Modify" List. Besides, change the fans and I would bet you void the IF warranty. They don't do much because they don't have to. There is not much voltage dropped across an "ON" FET so there is not very much power dissipated within the device. No real need to change fans. Of course, don't enclose the speed controllers in a tight, confined or closed area because no fan will help save you from ruin.
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Speed Controller Limits yaman Technical Discussion 11 15-01-2003 18:40
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
