Go to Post Wait is that how they got there, well how does one spotlight? - AlexD744 [more]
Unread 03-12-2012, 22:21
Re: Dashboard Meter for encoder shooter rate.
Since you're posting in the LabVIEW subforum, I assume you're modifying the LabVIEW Dashboard and not talking about the SmartDashboard project.
A meter indicator should work just by wiring the value to it the same way you wire the value to a numeric indicator. Make sure the range is set appropriately in the indicator's properties, so you can see the needle move more than just a pixel or two.
