Go to Post Be civil in all things and you will get far. - Wetzel [more]
Unread 04-12-2012, 10:40
mrcheese123 mrcheese123 is offline
FTC #4747
mrcheese123 is an unknown quantity at this point
Exclamation Omni-wheel accuracy
I am currently using Robot C to program with a tetrix kit. We have a base drive train with omniwheels and is setup like so:
I already have the code for telop written but in testing the motors have a big problem with rolling. When the bot goes diagonally, the motors slow to a stop at random (not every time) rather than just stopping. Also, occasionally, when the train is rotated, two motors stop and two motors roll to make it roll about an extra 45 degrees. Note that this occurs with different motors every time. Does anyone have any ideas on how to compensate for this?
Message me if you want to see the code, I don't want it leaking out everywhere.
Note: this is an FTC robot.
Unread 04-12-2012, 10:54
Re: Omni-wheel accuracy
Lift the bot off the ground and tell us what the wheels do when you command forward, reverse, rotate clockwise, rotate counterclockwise, strafe left, and strafe right.
Unread 04-12-2012, 10:58
Joining the 900 Meme Team
FRC #0079
I would suggest ensuring that you have feedback on each of the wheels. On our 3 wheel omni platform we drove it with and without velocity feedback (RobotC has this built in) and the difference was night and day. http://www.youtube.com/watch?v=qobHqf45SLc is before we put feedback on... but here is the one with feedback. http://www.youtube.com/watch?v=Qwg2cgNTAZE
In both cases, disregard the audio tracks they don't really add anything...
Unread 04-12-2012, 11:43
FTC #4747
Can you give me an example line of how to enable the feedback?(Too lazy to go dive around for it) I'm assuming encoders are not needed for this...
Thanks!
Unread 04-12-2012, 14:13
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
If you set the motors to brake instead of coast when your controller axes are within your dead band, that should solve your problem.
I agree that putting encoder feedback on the wheels is nice, but it's expensive ($56 per encoder), the encoders are touchy to get mounted properly, and it takes extra expertise to figure out how to program them once you have the instruments setup.
Unread 04-12-2012, 14:21
FRC #0079
I disagree, there is only about 20 lines of code running on that robot in the video and it was all done by our student programmers with only minimal pushing from our mentors for what to search for in the documentation. We also had no problems mounting the encoders, we simply followed the instructions. I will say they are bloody expensive. Encoders were the single biggest expense in that robot.
Unread 04-12-2012, 14:24
FRC #0079
Thanks!
Encoders ARE needed for this. As for how to enable it http://www.robotc.net/teachingmindst...nce/hp_PID.pdf If you're still struggling with it by Friday I'll pull our code and get it to you as an example. I know when I told our students that's what I wanted them to do it took them all of 20 minutes to get it working.
Unread 04-12-2012, 14:41
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
Our team has built 4 wheel omni drives like OP is describing on several occasions, and our experience is that they drive pretty nicely without encoder feedback. Maybe the 3 wheel version is touchier.
Encoders could solve the problem described by the OP. Setting the motors to brake instead of coast can solve it faster and cheaper. Adding encoders has additional benefits such as making the robot drive in a straight line and enabling more accurate autonomous driving.
I like instrument feedback. I just don't think it's worth $200 in this case.
Unread 04-12-2012, 14:47
How do you set a Tetrix motor to Brake?
Unread 04-12-2012, 14:50
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
I only know how to do it in LabView. The control Tetrix motor VI has a brake option that's pretty easy to find if you drop it into a piece of code. When I wrote omni drive code, I made a case structure that set all four drive motors to brake when all three drive axes were within a dead band.
Edit: my memory is poor. There is a separate VI provided in the FTC Toolkit called "Stop Motors". It's not an option in the run motors VI.
Unread 04-12-2012, 15:11
Some friendly advice? This is not the way to ask for help.
Unread 04-12-2012, 15:45
FRC #0079
I'm not sure whether the 3WD platform is touchier. My gut feeling tells me that it would spin a little easier and would show this problem a little more but I do not have data to back this up. I'm open for suggestions on how to collect this data.
I would disagree that simply placing it in brake mode would fix the core problem of motors moving at different speeds. It may fix the majority of it but for our team it was worth the $150 it cost to actually address the issue and to give us accurate autonomous navigation. It was also worth it to teach the lesson of the importance of feedback systems to my students.
I guess, my suggestion to OP would be to try the cheap and fast solution and if it meets your needs cool if not move on to using feedback.
Unread 04-12-2012, 16:22
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
I completely agree that using encoders is better overall and that it's a great thing for the students to learn how to do that.
In this specific situation, I don't think the core problem is best described as "motors are moving at different speeds." According to the quote below, sometimes the motors are continuing to run after the driver stops telling the robot to drive, while other times the motors stop right away. That problem as described would go away if the motor was told to stop instead of letting it coast.
We've had this exact problem with the same style of omni drive, and it drove a whole lot better after we incorporated the "stop motor" command when we weren't commanding the robot to drive.
No philosophical disagreements here... like I said, I agree that using encoders is better.
Unread 04-12-2012, 17:15
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Try calibrating the joysticks or adding some joystick deadband. Sometimes, even when the joysticks appear to be centred, they may not be giving an output of 0, which causes the motors to slowly turn. We had this problem in Vex, after linearizing the motor speed controller output, and adding some deadband really helped.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 05-12-2012, 12:26
FTC #4747
I added a deadband from -10 to 10 on both the X and Y axis and now it is perfect! Now I am trying to figure out configurable speeds with motors via buttons. Ex: Pressing button 1 sets a boolean value to true or false which dictates a variable to be set to 1 or 10 which is used to divide the motor power. However, switching the boolean values is not working. Suggestions?
