Go to Post Not all FIRST people are nuts. Some are threaded holes, rivets, velcro, or zip-ties. Anything but duct-tape. - Richard Wallace [more]
Unread 29-11-2012, 19:32
paper: Ballistic trajectory with air friction drag and Magnus
Better late than never.
For students (and teachers) interested in the physics, math, and computer simulation aspects of the ballistic trajectory problem.
Ballistic trajectory with air friction drag and Magnus by Ether
Unread 04-12-2012, 15:14
Re: paper: Ballistic trajectory with air friction drag and Magnus
Appendix A (2nd order integration) added.
Unread 10-12-2012, 20:28
Appendix B added. Graphs of simulation runs.
http://www.chiefdelphi.com/media/papers/2725
Unread 10-12-2012, 20:39
Michael Hill's Avatar
Pretty interesting. Unfortunately it looks like just a 2D simulation. The 3rd dimension can really play into the aerodynamics, for example, the surface velocity of a spinning ball spins relatively slower the closer you get to the "poles" of the sphere. This would be valid for an infinitely long, smooth cylinder. Not to say this doesn't provide valuable insight into how the Magnus effect affects rotating bodies in air.
Unread 10-12-2012, 22:03
It's still valid for a sphere, provided you use the appropriate coefficients.
Yes, insight. This was the purpose of the paper, to use Rebound Rumble as an "excuse" to get students interested in the physics, math, and computer simulation aspects of ballistic trajectories using a hopefully-not-too-difficult simplified model.
For Rebound Rumble, a simulation was not necessary and perhaps not even all that helpful for the purpose of building a winning robot. This is because, as many folks have already pointed out here on CD, the major design challenge of the shooter for Rebound Rumble was to get a shooter that was consistent from shot to shot. This was a big challenge due many factors, a key one being the variation in the ball due to manufacturing tolerances and changes in the ball's physical characteristics as it got worn. Once you've built the most consistent shooter you can, it's a simple matter to test-fire it to determine its performance.
Unread 11-12-2012, 06:27
Hmm, perhaps you're right (capital D instead of lowercase D in CD). However, finding the correct constants aren't so trivial.
Unread 11-12-2012, 18:27
If I had a shooter that could launch a ball with the same (known) launch speed and launch angle with and without spin1, I would try the following:
Set um=0 and adjust ud to match the trajectory1 with no spin.
Leaving ud at that setting, adjust um to match the trajectory with the expected spin. (repeat to get um's for various spins if needed).
Then I'd launch the ball at various angles (and speeds) and see how well the simulations matched the actual trajectories1.
It would make an interesting science project.
1Probably need a high-speed frame-timestamped video camera to determine launch speed, angle, spin, and trajectory
