Go to Post And trust me, the very last thing you want to see is me with time on my hands and access to power tools. - dlavery [more]
Unread 01-12-2012, 23:02
Re: pic: How many balls are in Team 68's robot?
The question is not how many balls are in 68's robot.
The REAL question is, how many of the balls in the robot can they score in one go, and for how many points? (And if you try to tell me that all of them are 3's, I'm going to say that you're bluffing--the wheel can't get up to speed quite that fast without spitting at least a couple for ones and twos, unless they can reverse it for a bit.)
Unread 01-12-2012, 23:08
Littleboy Littleboy is offline
FF: The Yellow Alliance (TYA)
Littleboy has a spectacular aura aboutLittleboy has a spectacular aura aboutLittleboy has a spectacular aura about
That depends on where they are shooting from and how much, if any, defense is being played.
Unread 01-12-2012, 23:12
Assume they can shoot from anywhere they can normally shoot with no defense.
Unread 01-12-2012, 23:25
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Well, since you asked,
  • <start at the fender>
  • The first one will fall out with some shaking, so maybe 1 pt
  • If we tap the last ball gently out towards the key and run the rollers backwards to smash the fifth through eighth balls into the ground, we can probably get the 4th ball out of the shooter. The second and third balls could then pop out, with maybe enough force for 2 2pts
  • This is the tricky part. We'd have to turn off the shooter, and stack the remaining four balls just right (the robot was designed to not carry four in the tower)
  • <drive forward (farther away) to key, with robot centered directly over front edge of key>
  • Shoot one ball for 3 pts
  • <drive backward (closer) on key, leaving robot ~1/4th of the way on the key>
  • Shoot four balls for 4 3pts
  • <Retrieve final ball from somewhere between key and coop bridge, return to previous spot>
So there you have it. I counted 23 out of a possible 27 points, if all the shots go in.
Yes there are nine balls.
The fourth shot will go farther than the next four because putting four balls in compresses them together; decompressing the first ball in that stack would cause it to jump out a little.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 02-12-2012, 14:30
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by robowrestler View Post
id say 8 but wow imagine if there was no limit on the number of balls you could hold.
https://www.youtube.com/watch?v=z7fep3iJ5e8
Unread 02-12-2012, 15:27
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
3 times the amount you should have.
Unread 02-12-2012, 15:36
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
What if there are really only three balls in the robot but they are just moving so fast that it looks like more?
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 02-12-2012, 15:49
I am curious as to what 469 can hold. They have that hopper that folds out.
Unread 02-12-2012, 16:14
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
With the speed that balls go through their system I was amazed the managed to hold on to 3 at one time!
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 04-12-2012, 14:52
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
This is the part where I wish I could find video of 469's 2006 robot shooting in autonomous.
Unread 04-12-2012, 16:17
Kyle A's Avatar
Kyle A Kyle A is offline
If it ain't broke don't fix it!
AKA: K Adams
FRC #0306 (CRT(Corry Robotics Team))
Kyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud of
Send a message via AIM to Kyle A Send a message via Yahoo to Kyle A
I believe This is a video of it. I remember seeing them in Atlanta.
http://www.thebluealliance.com/match/2006cur_qm50
Corry Robotics Team 306 1999-2015
Unread 04-12-2012, 16:23
CalTran's Avatar
Missouri S&T Senior
...they made a robot that shoots faster than it does this year? o.0 That is frightening. Can't imagine competing against it.
Unread 04-12-2012, 18:57
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
9 balls. 4 in their shooter and 5 in harvester.
Unread 04-12-2012, 20:11
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
25-30 according to 469 team members.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 05-12-2012, 23:09
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
That first few seconds, where they just score all those balls straight off the bat...
This robot-stuffing reminds me of competing at the MN State Fair-- since there isn't enough room for a full field, we have a variety of different game-related challenges to compete in. One of those was a force-of-impact test. I would have loved to see some of these robots try that (for the record, I believe 1816 won that-- their dual-CIM shooter broke the measuring apparatus if I remember correctly).
