Go to Post Like Mom blending a carrot in a chocolate milkshake to get vegetables in the diet. - Foster [more]
Unread 04-12-2012, 22:23
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
paper: Team 2410 Swerve Drive Project
Thread created automatically to discuss a document in CD-Media.
Team 2410 Swerve Drive Project by CalTran
Unread 04-12-2012, 22:24
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
Re: paper: Team 2410 Swerve Drive Project
I have heard of "continuous turn" potentiometers, that theoretically can turn indefinitely (with a set range of values that reset every 360 degrees or so). I don't have any experience with them - I'm hoping somebody will post who has - but these could potentially enable multiple revolutions per pod, as encoders would.
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 04-12-2012, 22:27
FRC #1836 (MilkenKnights)
These are called magnetic encoders: http://www.usdigital.com/products/en...tary/shaft/MA3
Unread 04-12-2012, 22:37
Absolute encoders can be magnetic or optical. All the optical encoders in the KoP are incremental.
Unread 04-12-2012, 22:44
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
There are several types of sensors that can be used
1) Incremental encoders: give pulses to say they've moved some part of a rotation. Quadrature encoders can tell which direction, pulsed encoders give a special pulse every revolution
2) Absolute encoders: these come in two common varieties, optical and magnetic (as Michael pointed out above). These are the most commonly used in FRC application that require infinite angular sensing
3) Infinite rotation potentiometers: quite simply these are pots that have no hard stops. They do exist, but they're usually not very good for this type of application because tend to have a dead-band.
Unread 04-12-2012, 22:50
Correct. I forgot about that. What are the performance differences between the two?
Unread 04-12-2012, 23:05
An incremental encoder provides pulses that can be counted (in the processor or FPGA) to give elapsed angle or speed. An absolute optical encoder has special markings on the disc (called a Gray code) which encode the disc's angle.
Unread 04-12-2012, 23:36
Gdeaver Gdeaver is offline
FRC #1640
Last year we used BI 6127V1AL.5FS magnetic sensors. Go to Digikey and search for that part number. Notice the cost. Down load the data sheet for specifics.They out put an analog voltage that corresponds to the angle. The voltage varies from .25 volts to 4.75 volts. With all things considered this works out to about .5 degree resolution. This is more of a c-rio limitation. For higher resolution one would have to go to a serial (SPI) type sensor. CUI has a capacitive absolute angle sensor with 12 bit resolution. Look at the AMT series. Avago also has a serial solution. The Bi sensors worked fine for us. The Bi's have a bronze bushing so they cant take high rpm's or mis alignment. There are special couplers to protect sensors from misalignment. You may want to check first choice for an example.
http://www.digikey.com/product-detai...393-ND/2620662
Unread 05-12-2012, 07:38
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Originally Posted by Gdeaver View Post
Last year we used BI 6127V1AL5FS magnetic sensors. Go to Digikey and search for that part number.
That part number gives me nothing in DigiKey. Could you post a link to the page?
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 05-12-2012, 07:44
FRC #1640
Sorry I left out the " . " Link
Unread 07-12-2012, 17:28
3.2 Schedule
If this project is to be used in FRC season then it would be preferred for the project to be complete by January 5th. The ideal completion date would be somewhere mid-December, which would allow for a few weeks of practice to get used to the omnidirectional nature of the drive and non-intuitive control.
Conception of Idea………………11/05/12
Research of Swerve Drives…….11/12/12
Design Team Swerve…………...11/24/12
Purchase of Materials…………...11/27/12
Fabrication Complete……………12/07/12
Programming Complete…………12/10/12
Practice Time…………………….12/11/12
Is the fabrication complete?
Unread 07-12-2012, 18:52
CalTran's Avatar
Missouri S&T Senior
No, sadly we got a bit behind when our teacher went to the Autodesk University conference in Vegas last week and we couldn't purchase materials. We should have the modules completed on Tuesday, hopefully.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 15-12-2012, 22:07
I'm curious how your project is coming along. Any good news?
Unread 16-12-2012, 15:42
CalTran's Avatar
Missouri S&T Senior
Well, depends on your definition of good news. We've completed a module, and are working on the other 2-3 modules, depending on what material we can scrounge up for our rapidly ending off season. This prototype may continue on into regular season, with an "upgraded" swerve debuting on our robot at Greater Kansas City, game allowing of course. If the game does not allow for it, then we'll simply finish the prototype, slap it on to a base, and stick our 2012 robot sans-drive on top for a snazzy demo robot.
Unread 16-12-2012, 16:04
AdamHeard's Avatar
Lead Mentor
If your goal is to have an effective scoring design for 2013, it's probably a bit late in the game to implement swerve.
There is a lot of tuning, debugging, iteration, etc... on the software and controls for it.
