Go to Post If a kid was in FIRST and no one was around to see it, do they still get inspired? - Katie_UPS [more]
Unread 03-12-2012, 22:00
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
[HELP] C-Rio connection issues
One of out teams computers will not connect to the robot by direct ethernet for an unknown reason. The crio will connect to other computers with the same cable and the computer will connect to other networks but no the crio. We have reinstalled the drivers multiple times and each time it will connect until the computer is restarted again. Is there a specific driver for the crio? What else might be the issue?
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 03-12-2012, 22:06
Re: [HELP] C-Rio connection issues
Firewalls can interfere with communication, disable them.
Multiple NICs can confuse things, Disable all NICs except for the one you are using.
Check that the IP address on the one active computer NIC has been set to 10.te.am.5, netmask 255.0.0.0
Unread 03-12-2012, 22:14
inkspell4's Avatar
All connections other than ethernet were disabled and the computer was configured correctly
Unread 04-12-2012, 08:14
Do you see a green "connect" light on the cRIO's Ethernet port, or does it remain dark?
Almost every modern device with an ethernet jack will connect to any other device using either a patch cable or a crossover cable. The cRIO is an exception; it will not switch its transmit and receive pins to accommodate what is at the other end of the cable. If your computer similarly does not automatically switch, either because it's not designed to or because it's been configured not to, then a crossover cable ought to make the connection work.
Unread 04-12-2012, 18:10
inkspell4's Avatar
I will try the idea of a crossover but their are not green lights
Unread 04-12-2012, 23:09
Hang on a second.
Are you trying to connect the computer directly to the cRIO? If so, why? That would mean you have to disconnect the cRIO from the D-Link. The normal thing to do would be to plug the cable from the computer into one of the D-Link's other ports, leaving the cRIO and D-Link still connected. The D-Link should be able to mediate between devices to make a crossover cable unnecessary.
Unread 05-12-2012, 13:43
inkspell4's Avatar
Somebody messed up our dlinks settings
Unread 05-12-2012, 14:57
Not to sound flippant or anything, but why don't you just set them back to what they should be?
Unread 05-12-2012, 16:48
If you're using Ethernet to connect to the DLink/cRIO, then the DLink settings really don't even matter for this job. It's being employed only as a switch.
Incorrect settings will matter when you want to use it for wireless.
Unread 05-12-2012, 21:00
inkspell4's Avatar
We are in a rush right now to get a base robot up and running for the competition an just haven't had time
