Go to Post Improve yourself. Try not to tear others down. - Tom Line [more]
Unread 05-12-2012, 13:18
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Portable basketball hoops
What have teams been using for a basketball hoop solution for off season demos?
We ending up building the plywood backboard, but used a old high school hoop (very heavy gauge!) and a 2x4 stand, similar to what was spec'd in the manuals. However, that doesn't fit in our trailer and we modified it to have some hinges and such, but that design is not holding up.
Wondering what other teams are using when they go to demo at a site that doesn't have a b-ball court (or gym floor that they don't want a robot running around on)
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 05-12-2012, 13:51
Re: Portable basketball hoops
You could make an elevator type lift with a detachable base/locking casters. Could be a cool exercise for your mechanical team. Could probably just manually raise/lower it and use something simple to lock it into place. OR you could create one that elevates up and also uses a linkage arm like many 2011 robots had. Of course this would probably require a lightweight backboard. http://www.freepatentsonline.com/6645095-0-large.jpg
Unread 05-12-2012, 14:07
Should have mentioned it needs to be fairly easily assembled/disassembled into pieces that will fit in our small trailer.
John Vriezen
Unread 05-12-2012, 17:02
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
I had an adjustable hoop that lived in my driveway for 7 years that works fine. It has two nested poles that allow adjustment down to 8 feet. If I remove the two bolts that hold the backboard to the post, it stands around 7.5 feet tall. It has 2 wheels for transport, and fills with water for extra stability if we need it. It's rollable (into a trailer) with or without the water. Used ones should be easy to find for pretty cheap.
I started a different thread to see what folks are using for a more durable basketball, but no response yet. Any feedback is appreciated.
FRC Team 3489 "Category 5"
Unread 05-12-2012, 18:49
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
What I've been thinking about doing is reducing the backboard size to just the reflective tape part (or whatever part you shoot off of) and the part that holds the hoop, and then making a reduced size basketball hoop. The reduced size would be about 4-6ft tall, depending on what height you want to shoot at. Assuming we're talking about just one basket, a simple box frame with two shorter a-frames perpendicular on the sides to support it upwards would suffice. Then, you can put this mini-hoop up on a table or some elevated surface where you are demo-ing. Folding tables work too.
Academic Student (Forever)
Unread 05-12-2012, 18:59
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I just purchased a portable basketball hoop for the dual purpose of my kids christmas present and the 2012 robot.
The vertical pole that supports the hoop has a pin in the middle so it can be disassembled and put in a trailer easily. The hoop is adjustable to 8 feet.
Unread 05-12-2012, 19:23
Can you give me a link to what you purchased ?
John Vriezen
Unread 07-12-2012, 02:42
Tom Line's Avatar
I ended up with this one because it was on sale:
http://www.dunhamssports.com/product...ortable-66291/
The vertical post is actually 3 pieces. The last two pieces join between the base and the adjustment handle (and it actually goes down to 7.5 feet). The post is a beveled slip-fit that jams together as it slides together. I drilled through the bottom tube and put a bolt through so that the two tubes fit together but are never completely jammed (because it's a pain to get them apart if they are jammed tightly!). Then I drilled a second hole through both and put a bolt through that they couldn't turn or come apart. Just unbolt the bolt that goes through both and they slide apart.
Unread 07-12-2012, 23:17
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
our team recently built one, for a robot competition we were in that involved us basically showing off our robot. It seperates into 6-7 pieces so that it can fit in a car, and we even painted it red, and white, and blue to grab attention. It is not the height of the game hoops. instead the top of the backboard is somewhere between 8-9 feet, so that its easy to put into any room, even when there's a low ceiling. We understand its not standard game height, but its better than nothing, and truly does make an impact on the audience when demonstrating your robots accuracy.
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 08-12-2012, 00:14
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
We actually just attached a plywood backboard we made and hoop to the minibot polls and base from 2011 with u bolts.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 16-12-2012, 11:11
We ended up doing something very similar-- in fact the same except instead of 2011 bases we used cinder blocks with EMT (mini-bot pole pipe) splicer connectors that were half embedded in concrete set in the blocks. Setup/takedown/transport are all very good. Basket is shorter than three point Rebound Rumble hoop, but most demo audiences don't know that, of course..
We demo'd at Rochester MN FLL tournament yesterday and prior to awards being handed out in the community college theater, we shot baskets on stage and shot balls into the crowd.. (Not for them to keep, but they tried making baskets from where they sat) Also one of our mentors played HORSE against the robot. (Lost HOR to zip) It went over very well.
John Vriezen
