Go to Post The best metrics are your own. Do you see the impact of your efforts in your community? Do you feel like you should/could have won Chairman's, but another team was even more deserving? That's how you know FIRST is really working. - dcarr [more]
Unread 16-01-2003, 13:10
Kevin N Kevin N is offline
#0451 (The Cat Attack)
Kevin N is an unknown quantity at this point
Bosch Gearbox. . . High or Low Gear
Does anyone have any advice on which gear(high or low) you should design a drive system? We plan on using 1 speed. I do realize the low gear is more efficient than the high gear(97% vs. 92%) but reading one of the "White Papers " on last year's gear box, there was procedure describing a spacer ring that could be placed in the gear box locking it in high gear. Does the same concept hold true for this years gearbox? If so, I guess its. . . high gear?
Unread 16-01-2003, 13:15
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
use it in low gear, it will provide more torque, and still provide decent speed, especially if you gear it well using sprockets, gears, whatever.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 16-01-2003, 14:29
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
we're using high gear and gearing it down considerably...
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
What does the Chairman’s Award have to do with a robot contest? Ed Sparks Chairman's Award 32 15-02-2004 13:39
White Paper Discuss: Locking the Bosch 3360 Drill in low gear CD47-Bot Extra Discussion 4 05-08-2003 02:10
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
low gear vs high gear archiver 2000 1 23-06-2002 23:07
KSC Results archiver 2000 2 23-06-2002 22:19
