Go to Post As a team sponsor, we are more concerned with the behavior, attitude and commitment to FIRST ideals than specific performance in the competition. Some of our teams perform well, some struggle, some are in the middle. We support them all in every way we can. - Chris Fultz [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-12-2012, 09:26
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Re: 2013 4" Performance Wheels
It looks to me like the shaved down portion of the tread at the feed through point is leaving a significant flat spot. Isn't anyone concerned about a bumpy ride? I also think a layer of double sided tape applied first would help tread adhesion to resist the lateral torque, particularly for the areas furthest from the attachment point.
FRC Team 3489 "Category 5"
Unread 06-12-2012, 10:58
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Very nifty design!
@971: Did the flat part of the round wheel cause any 'drive straight' autonomous routines to NOT drive straight? If so, how did you compensate? Did the extra bump cause excessive noise in the gyro?
GitHub
Unread 06-12-2012, 12:00
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
One thing to note is that the new hub is slightly thicker (axle direction) than the previous generation performance wheel. The old wheel was 0.74", the new one is 0.80". Fortunately we were able to absorb the difference by using a thinner wheel spacer washer.
Unread 06-12-2012, 15:36
Originally Posted by JesseK View Post
Very nifty design!
When you are running on carpet, you don't notice. We did what Andy recommends and shaved the ends down. I would say that the bump on our wheels is similar to the bump with the rivets holding the ends of the tread down.
Unread 14-12-2012, 13:12
We just got several of the new AM 4" performance wheels. Aluminum mag wheels for the robot, gotta love it. Very nicely made... should last a long time. I used roughtop for tread and found a few things:
1) Instead of shaving down the ends, if you get the bumps/waves of roughtop to interlock before inserting the 2 tread ends into hole it fits... just barely. You have to put the zip tie through the hole in the treads with a pair of needle nose pliers or hemostats AFTER you insert the tread through the hole.
2) In an attempt to eliminate/reduce the flat spot, I added "tabs" on the ends of the tread to keep the tread continuous on either side of the hole (see attached picture). Not sure it makes any difference as the flat spot is very minimal... but it looks nice and they lay flat.
3) The length of tread is slightly longer than the circumference of the wheel as the bending axis of tread must be near its center.
Attached is the flat pattern drawing.
