Go to Post Some things in life are far more important than Robotics. - IMDWalrus [more]
Unread 21-11-2012, 21:25
Re: Cannot move robot
Originally Posted by Butter's View Post
No error on console, and I was able to FTP into the robot fine. However, which directory is it in on the cRio?
For java, it's in ni-rt/system/ and called robot.suite
Unread 21-11-2012, 22:55
Butter's Butter's is offline
AKA: Joe Kent
FRC #0522 (Robo Wizards)
Butter's is an unknown quantity at this point
Ah, thank you. I'm guessing I should try deleting this file & re-downloading when I get back from break.
Unread 26-11-2012, 14:17
AKA: Joe Kent
Just want to quickly add after a few days of debugging the problem was resolved!
Thanks everyone who replied / helped out.
Unread 26-11-2012, 14:50
What was the solution?
Unread 26-11-2012, 15:57
AKA: Joe Kent
It was a mix of problems.
First one I found was when I added the compressor in the code (To test if it was jaguars or something else), I made a typo in the port. So it was (1,1), which resulted on a start up error.
After that I found a robot specific issue I'm too lazy to write about, and I forgot the other one... I guess I was too excited that I fixed it
Unread 26-11-2012, 16:08
Some friendly advice? If you come to CD asking for help, you should be willing to share what you've found when you figure it out. It's considered the courteous thing to do. Others may benefit from your experience.
Unread 26-11-2012, 17:28
AKA: Joe Kent
I was hoping it wouldn't be a large deal :/ . I myself only found what the problem was (had to go to class), I didn't fix this exact one. I could ask the guy tomorrow what he did. The most I know was the problem and how I assume he fixed it. Lazy probably wasn't the proper word to explain that.. Sorry!
Unread 06-12-2012, 13:39
279 EMPIE's Avatar
279 EMPIE 279 EMPIE is offline
Head Progammer
AKA: Matthew Empie
FRC #0279 (Tech Fusion)
279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice
Send a message via AIM to 279 EMPIE
Im not 100% sure but i thought the Jags showed a green Light for Forward, Red Light for Revearse, and a orange Light for nothing because if im right about that your Jags would not be reading anything in the code.
If they are not reading it could be a couple reasons:
1. I would check to make sure you have the ports right Digital Module should be in Slot One or Two not sure which, and on the Side Car the PWM port need to be put in right. In the program your code should have:
public Jaguar Jag1 = new Jaguar(1,(PWM Port Number));
2. There is something wrong with your code and i cant help with out seeing it.
If the Jags are being read by the code and are still not working, make sure that you set Jags. This means you use a paper clip on the jag reset button untill it blinks then you run your robot full speed forward and full speed backwards then it should set it self. <-- this is the way we fixed are robot jags two years ago
2011- Programmer, Electrical, and Web
Cleveland Regional
2012- Head Programmer, Web, Driver
Pittsburg Regional, Saint Louis International
2013- Head Programmer
Cinnicinatti Regional, Taraho Regional
Unread 06-12-2012, 13:42
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
I should read next time ^^^
Cleveland Regional
