Go to Post My lasting impression of 217 (for years now) has been based on how their robot looks, dynamically. It is poultry in motion. :) - Richard Wallace [more]
Unread 28-11-2012, 21:40
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
C-Rio problem
Hello,
Today we were teaching one of the programming students how to image the c-rio and upload code. (First time it has ever been done in java)
We imaged it with the image version 49 for 2012 and rebooted the robot at this point we got a connection error for the OTA ( at this point i dont have the exact error message) we reimaged the crio restarted the computer and crio and attempted again to upload code but this time the crio would not connect to the computer ( the cable was plugged in and the link light (green) was on but the status light (yellow) was not even blinking)
Should i do a reset on the crio and how would i do so some documentation would be helpful
Thanks in advance
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 29-11-2012, 17:54
inkspell4's Avatar
If it helps we are using netbeans with the frc update 3077
Unread 30-11-2012, 23:56
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: C-Rio problem
I'm not sure if this is the same as your problem, but we had a problem connecting to the cRIO and it turned out that the computer had the wrong static IP. I changed it to 10.te.am.5 and it worked.
I code stuff.
Unread 01-12-2012, 17:26
inkspell4's Avatar
We found the problem and it was that the drivers for ethernet were bad
Unread 06-12-2012, 13:21
279 EMPIE's Avatar
279 EMPIE 279 EMPIE is offline
Head Progammer
AKA: Matthew Empie
FRC #0279 (Tech Fusion)
279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice
Send a message via AIM to 279 EMPIE
Re: C-Rio problem
I agree i think it is a IP problem, make sure when you imaged the cRIO that you put the Team Number in it. If you did this correctly the IP of the cRIO will be 10.TE.AM.2 and the IP u put in the computer will be 10.TE.AM.5
When you do this Netbeans should find it, if not go into NetBeans and goto the Options for the FIRST Plugin and make sure your team Number is set on that.
2011- Programmer, Electrical, and Web
Cleveland Regional
2012- Head Programmer, Web, Driver
Pittsburg Regional, Saint Louis International
2013- Head Programmer
Cinnicinatti Regional, Taraho Regional
Unread 06-12-2012, 15:29
inkspell4's Avatar
Wait now it doesn't work again
Unread 06-12-2012, 16:54
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: C-Rio problem
Could you be more descriptive? Does it show the same symptoms as before, or is it doing something different?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 06-12-2012, 17:25
inkspell4's Avatar
Yes the same symptoms
