Go to Post If there is anything I have learned from ChiefDelphi, it's to never underestimate the coding genius that is Brandon Martus. - Amanda Morrison [more]
Go Back   Chief Delphi > Announcements
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
  #106   Spotlight this post!
Unread 06-12-2012, 19:20
Andrew Lawrence
Posts: n/a
Re: VEX Robotics Relaunches VEXpro Product Line with over 120 New & Improved Products
Can you post the dimensions of the VersaHub? Definitely looks like something we'll be using in the near future.
  #107   Spotlight this post!
Unread 06-12-2012, 19:23
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
I've thoroughly read all the product pages along with a few other team members, and for the items like the ballshifters, it is a bit confusing during the first read...
I agree. A close read reveals that the pneumatic and encoder hardware kits are included with the shifter. Those items should probably have "(included with the base kit)" or something similar added to the description.
I hope if you order the optional gear kit along with the 3-stage shifter you get both the 60:24 and 64:20 gear sets - because that's what I did and that's what I wanted...
  #108   Spotlight this post!
Unread 06-12-2012, 19:40
DampRobot's Avatar
Physics Major
AKA: Roger Romani
JVN, can you comment on the material of the Ball Shifter casing? I assume it is some sort of plastic. I've had a lot of trouble with polycarb sideplates making motors overheat in drive gearboxes in the past. Have you tested for this? Also, any plan to sell aluminium versions of the casing (as side plates with spacers)?
-Plutarch
  #109   Spotlight this post!
Unread 06-12-2012, 19:48
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
The Ball Shifter casing is Glass-Filled Nylon. I've never heard of motors overheating as you've described. We are not planning to sell an aluminum version, or a side-plate + spacer version -- though the design does lend itself to teams being able to make their own.
-John
  #110   Spotlight this post!
Unread 06-12-2012, 19:54
DampRobot's Avatar
Physics Major
AKA: Roger Romani
-John
Funny, we've often had problems with Fischer Prices overheating in the drive, and many teams use fans on their practice robots to keep their CIMs from overheating (even with aluminium side plates). A little surprising, but interesting nonetheless.
-Plutarch
  #111   Spotlight this post!
Unread 06-12-2012, 20:16
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
Are the parts lists for the 2 and 3 stage ball shifters mixed up?
The 2 stage lists "Ball Shifter Long Output Shaft Assembly with 60t and 44t Ball Shifter Gears"
The 3 stage lists "Ball Shifter Short Output Shaft Assembly with 60t and 44t Ball Shifter Gears"
The images (and CAD) show the 2 stage with a shorter output shaft than the 3 stage, which I assume is correct.
Any ideas for using the 3-stage shifter for a WCD/direct driven center wheel? The lower housing hex standoffs look like they will interfere with putting a 16T #25 sprocket on the drive axle to power the front/rear wheels. Turning the gearbox sideways would work, but that eats up >2" of ground clearance, meaning at least 6" wheels would be required.
Team 2590 Mentor [2009-2014]
Team 5895 Mentor [2016-Present]
  #112   Spotlight this post!
Unread 06-12-2012, 20:52
FRC #1836 (MilkenKnights)
As far as I've seen, to get a reasonably speedy robot, you need to use 6" wheels anyways. The ball shifter ratios really aren't built for direct driving 4" wheels. That said, the 3rd stage is really versatile. There are a a lot more options that you can get by switching out the 2 default 3rd stage gears ratios for different gears.
  #113   Spotlight this post!
Unread 06-12-2012, 21:04
How about turning the gearbox upside-down so the CIMs are on the bottom?
  #114   Spotlight this post!
Unread 06-12-2012, 21:05
What ratio would you want to have in order to drive 4" wheels?
  #115   Spotlight this post!
Unread 06-12-2012, 21:08
IIRC a 30T vex gear and a custom 54T gear make a nice 15-16 FPS(assuming no friction).
  #116   Spotlight this post!
Unread 06-12-2012, 21:19
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
For anyone interested, a friend of mine made a consolidated zip folder with STEP files for every available vexpro product that was just released.
He's hosting it on his google drive: https://docs.google.com/file/d/0Bx6d...FyZTdQSlE/edit
Beware: Google Drive has a download cap, so if someone were to mirror this, that would be appreciated.
  #117   Spotlight this post!
Unread 06-12-2012, 21:25
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Or, the new VEXpro 34t and 50t will cover the right C-C distance, and provide a theoretical 16.17 fps in high gear.
  #118   Spotlight this post!
Unread 06-12-2012, 21:27
scottandme's Avatar
AKA: Scott Meredith
That's the orientation I was looking at.
With 5" wheels, the 60:24 3rd stage would give you speeds of 5.5 ft/s and 12.6 ft/s (probably ~4.5 and ~10.2 after accounting for 80% of theoretical). Current draw would be right under 40A at stall in low gear, which is ideal. Would have been near perfect for the 2012 game.
Playing with making aluminum plates to replace the housing, will be heavier but at least mounting will be easier.
  #119   Spotlight this post!
Unread 06-12-2012, 21:40
Now I see what you mean. None of the hex standoffs seem positioned optimally for driving the front/rear wheels on a WCD.
  #120   Spotlight this post!
Unread 06-12-2012, 21:51
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
http://www.team3309.org/VexPRO_CAD.zip
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
