Go to Post A robot with hands would be cool! - Koko Ed [more]
Unread 16-01-2003, 13:02
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Robot Digital Input
I set up four linits switches
The problem I am having is stopping the forward motion of the motors. I wired up pin 4,5,18,and 19 all to ground which were 3,6,17,and 20
I am reading 4.92 volts at the switches but when the switches close the motor still works in the forward or backward direction.
I have two motors that I wanted to stop. two limit switches per motor.
am I reading the reference guide right.
I am using the joystick in port 3 and joy stick in port 4 on the operator Interface
Any help would be great this is the first year we are using limits switches ( 8 years without )
Unread 16-01-2003, 13:30
Happy Birthday! rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Electrically, I think you are doing the right thing in terms of pins. However, you shouldn't be reading +5 anywhere. Are you sure you wired this stuff into the digital inputs port on the RC and not the analog? It looks like that may be the problem as pins 3,6,17,and 20 all carry +5V on the analog port. If you move your connector to the digital input port, it should work.
Unread 16-01-2003, 13:40
crazycliffy crazycliffy is offline
crazycliffy is an unknown quantity at this point
I also believe it is software...
so make sure the software variables in the PBASIC
code gets changed. Because below means that
the default PBASIC code will do the following:
the Full-Size RC Reference Guide says:
for
Pin 4 "PWM 3 won't go forward if rc_sw5 is ON"
Pin 5 "PWM 3 won't go forward if rc_sw6 is ON"
Pin 18 "PWM 4 won't go forward if rc_sw7 is ON"
Pin 19 "PWM 4 won't go forward if rc_sw8 is ON"
Unread 16-01-2003, 14:03
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
If he was reading the voltage at an unconnected (or switch open) digital input pin he would read +5V due to the internal pullup resistor.
Unread 16-01-2003, 14:04
FRC #0061
Rookie Year: 1995
It is on the digital side and I am only going off the default.
Plus the light will not go on. pin 8 on the relay should turn the light on.
I can put the light on pin 1 of the relay and pull the trigger on the joy stick and the light will go on.
Unread 16-01-2003, 14:31
FRC #0061
Rookie Year: 1995
the problem was in the robot controller
I replaced with last year controller and it works great
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
