Go to Post Try to remember, FIRST is like life, it is about the journey not the destination. - rees2001 [more]
Thread Tools Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Unread 07-12-2012, 12:37
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Re: FTC 2012 RobotC IR Sensor Programming and implementation
Phil,
We're using LabVIEW, and for us, the IR Seeker outputs two sets of data:
[1] is the Direction, which is an integer value, 0-9 (we think)
[2] is a Signal Strength array, with the five values
We discovered this later last night, so we won't be able to do any testing until tomorrow. So, if you know, what sort of data kicks out of that array? Is it just positive numbers, such as 0-10, or 1-100? How does it show it has ZERO signal strength?
I think we can do math on those values, as you suggested, but I'm just unsure what exact data is used to represent those signal strengths.
FRC 2656 | FTC 5526 | VEX 9656
Unread 07-12-2012, 17:27
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
The signal strengths are positive numbers .. maybe in the 0-100 range.
You don't need to do any math per-se...
The only time you are interested in the 5 discrete sensor values is when you are ON a narrow beam (2,4,6,8).
Then all you do is look at the relative strength of the two adjacent IR sensors... this just tells you which side of center, the beacon is.
Here's what I did the first year we used the IR seeker...
Made a compass out of paper (with degree markings)
Mounted the compass and IR Seeker on a camera tripod so I could spin it.
Mounted an IR beacon on a wall in front of the tripod.
Wrote an NXT program to read the seeker and display the Beam number and 5 signal strenghts.
Sat on the floor and slowly rotated the tripod head and watched the numbers changing.
You can learn a LOT this way. We discovered the whole 5 Deg, 60 deg thing way before they published the white paper. We could auto aim and shoot wiffle balls into the spinning goal from the corner of the field.
I personally think Hitechnic missed the boat on this one, and should do a Seeker V3 that has 4 IR receivers centered on "forward" so the 5 Deg beam is centered, rather that 30 Deg off to one side.
Phil Malone
http://www.GEARSinc.org
Unread 12-12-2012, 03:06
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
This I/R detector makes no sense to me.
Issue #1 -What are the 9 "zones" and how does the 5-detector array define them. If the sensor "sees" 240 degrees, across five dector array zones, then is each detector handling 48 degrees of the the total 240 degree span, or do the individual detectors have wider overlapping views (maybe 60 degrees with 12 degree overlap?
Issue #2 - What causes the nine zones to have different "beam" arc widths (5 & 60 degree)? In fact why is the term "beam" even applied to the sensor, since the actual I/R energy beam is being sent from the beacon & no "beaming" should happen at the sensor? Is there some kind of prismatic beam focusing effect happening in the lens that slices up the incoming I/R energy such that it concentrates narrower slices (5 degrees worth of the 240 degree field) on the the radial midpoint axis between detectors, and it slices 60 degree slices of the 240 degrees of incoming I/R energy onto the radial central axis of each of the five detectors?
Issue #3 - If the sensor's central axis for zone 4 field view (located halfway between detectors 2&3 - with a 0-1-2-3-4 detector numbering scheme) is pointed straight ahead, and sensor is positioned at center of the bot, then when the data readout list indicates that the five detector array readings are coming from the zone 4 sector of the incoming I/R energy field (5 degree segment), then, when the bot is lined up centered in front of the beacon, shouldn't the detector array list of the five zone 4 direction array data values be showing that the highest number will be for the middle detector and the # values for the two adjacent I/R array detectors should be BOTH be somewhat less than the middle detector value, AND also nearly equal to each other?
Issue #4 - As the robot moves, what causes the I/R sensor to cycle through the zone numbers as it updates the data list with new values? Is it just that the sensor somehow determines that the peak energy is coming from that direction? How does the sensor ignore the incoming I/R energy from the other zones, and how does it decide which four to ignore?
I really don't understand how the sensor slices up the incoming 240 degree field of I/R energy into the 5 & 60 degree segments, and how the array knows what energy is hitting it from which slice of the 240 degree field?
Does the lens block incoming I/R energy from hitting the detector with some sort of staggered, variable angular width blinders that cast shadows on the detector, only allowing a certain sized (5 or 60 degrees) angular slice of the I/R energy reach the detector according to the directional line from the beacon to the sensor and the sensor pointing direction?
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 12-12-2012, 08:06
PhilBot's Avatar
AKA: Phil Malone
Hey Dick.
Check out this doc from a few years back...
http://www.usfirst.org/sites/default...icsR2-rev2.pdf
The IR seeker is made using 5 discrete sense elements. Each element has an approximate 60 Degree sensitivity area. These also overlap each other by about 5 degrees to form a dusl sense area (beam). This overlap is usefull because it provide a narrow sense area, but there is not one that is centered on the "forward" direction of the seeker.
If you want to understand it beter, chek out some related IR seeker links here:
http://www.usfirst.org/roboticsprogr...ionalresources
Phil Malone
Unread 13-12-2012, 09:46
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
We were able to find some sample code that shows the 5 signal strengths on the NXT brick. The values seem to go from 0-255. Strangely enough, they show some readings we didn't expect, like having a sort of 'dead zone' in what would be Direction 3.
Again, as a LabVIEW team, we're thoroughly confounded with using this thing for navigation. We're gonna keep plugging away though, and if we get some stuff that works reliably, we'll post the code here.
