Go to Post Cooling fans? Never had the need. Then again, we're talking New Jersey in March. Radiant heaters might be a better choice, or maybe snow boots. - DonRotolo [more]
Unread 05-12-2012, 10:06
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Rubber Basketballs
Our team is looking at buying more basketballs for demo purposes. Foam basketballs seem to be available online (no longer at AndyMark) but we all know how easily damaged they are, and they're not exactly cheap, either. Does anyone in the CD community have experience with rubber basketballs for demo events? A size 4 seems to be just a little smaller at a 24.5" circumference. What we don't know is: does the extra bounce cause an issue, and do they perform comparably with a wheeled shooter? I imagine the air pressure could be varied, but I'm wondering if this learning curve has already been climbed. Thanks for any input.
FRC Team 3489 "Category 5"
Unread 07-12-2012, 16:30
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Re: Rubber Basketballs
If you deflated them to the compression of the foam balls I think it would be fine in a wheel shooter.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 07-12-2012, 16:42
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
Wow, why haven't we thought of rubber balls for demo purposes!!! the foam balls get destroyed after some of our events, when we are running 3-4 balls through the robot nonstop for 5-7hrs (with short cool down breaks).
Although we haven't used rubber balls, i would assume, they will have a lot more "bounce". That means that the faster and harder the robot shoots it, the more likely it will bounce off the backboard and miss. Usually when at a demo, a robot is close to the hoop, so it will not bounce off the backboard as much.
The way to "fix" this bouncing problem will probably to just change the speed (if you can from your controls) and/or to adjust your angle (if you also can from your controls)
(If you cant adjust these, maybe its a good offseason project.)
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 08-12-2012, 00:47
One of the biggest potential differences is the mass of a rubber ball vs a foam one. A heavier ball will shoot slower than a lighter one.
Unread 08-12-2012, 01:00
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Helium. Also, keep in mind any rubber ball, basketball or otherwise, won't have as much give as a rubber ball does when being compressed.
Academic Student (Forever)
Unread 08-12-2012, 03:56
techedguy's Avatar
techedguy techedguy is offline
Technology Education, PFHS
AKA: Sal
FRC #4520 (Roboteknix)
techedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nice
We did shoot a volleyball through ours a few times. Not as hard as basketballs by nature and typically lighter. Best wishes - let us know what works out for you.
Salvatore Lorenzen, M.Ed, Ed.S.
Mentor/Coach/Teacher
I am not who I hope to be, but I am trying. I am giving it my all to improve me; and I’m thankful at the end of each day that I’m not the guy I used to be.
FRC #4520 - Misfit Toys
2012 Spokane Regional WFA
2009 Idaho GIANTS Award
Unread 10-12-2012, 15:31
HumblePie's Avatar
AKA: Mista Doug
Well, based on the responses, I guess we're the guinea pigs, eh? They should arrive Wednesday, I'll let everyone know what we find out.
