Go to Post I know alot of the rookie teams were helped out alot this year. Do the same thing for the rookie Volunteers as well. - wilsonmw04 [more]
Unread 08-12-2012, 13:45
CosmicCricket CosmicCricket is offline
FRC #2517
CosmicCricket is an unknown quantity at this point
Re: Need help with encoders
What I have so far is some skeleton drive code, and I'm pretty sure the encoders are giving me something because I am getting 0's and 1's depending on the way the motors are spinning. However, GetRaw() is supposed to count up or down, not return 0's and 1's.
The encoders are connected to the DIO slots indicated in the code.
#include "WPILib.h"
class DefaultRobot : public SimpleRobot{
	Joystick joystick;
	Jaguar leftDriveJag;
	Jaguar rightDriveJag;
	Jaguar combineJag;
	Encoder encoderL;
	Encoder encoderR;
public:
	DefaultRobot(void):
		joystick(1),
		leftDriveJag(1),
		rightDriveJag(5),
		combineJag(3),
		encoderL(4, 3, false, Encoder::k4X),
		encoderR(2, 1, false, Encoder::k4X)
				Watchdog().SetExpiration(.75);
	void Autonomous(void){
	void OperatorControl(void){
		Watchdog().SetEnabled(true);
		encoderL.Start();
		encoderR.Start();
		while(IsOperatorControl()){
			Watchdog().Feed();
			//Operator Control
			printf("%d\n", encoderR.GetRaw());
			printf("%d\n", encoderL.GetRaw());
			if (joystick.GetRawAxis(4) > 0.2 || joystick.GetRawAxis(4) < -0.2) { //Deadband of .2
				leftDriveJag.Set(joystick.GetRawAxis(4)); //Run left motors based on left stick value.
			} else {
				leftDriveJag.Set(0); //Set the motors to 0.
			if (joystick.GetRawAxis(2) > .2 || joystick.GetRawAxis(2) < -.2) { //Deadband of .2
				rightDriveJag.Set(joystick.GetRawAxis(2)); //Run right motors based on right stick value
			} else {
				rightDriveJag.Set(0); //Set the right drive motors to 0.
			if (joystick.GetRawButton(2)){
				combineJag.Set(.5);
			} else {
				combineJag.Set(0);
			if(joystick.GetRawButton(3)){
				combineJag.Set(.25);
			} else {
				combineJag.Set(0);
START_ROBOT_CLASS(DefaultRobot);
Unread 08-12-2012, 15:15
An encoder that only returns 0 or 1 indicates that the B input is not working. I would double check your wiring and encoders.
