Go to Post The big lesson we learned ... our past does not limit our future, that superior attitude will beat out big budgets. - [more]
Unread 08-12-2012, 20:38
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
How to use a solenoid on a robot?
I'm a relatively new member (1 year) on a robotics team and I would like to know how solenoids can be used on a robot. I did a little research and found some industrial applications such as pinching, locking, and latching, but realistically HOW is a solenoid attached to and used on a robot?
Unread 08-12-2012, 20:54
JJackson's Avatar
JJackson JJackson is offline
FRC #0781 (Kinetic Knights)
Team Role: Driver
JJackson is an unknown quantity at this point
Re: How to use a solenoid on a robot?
In 2004 we used a linear solenoid as a to hold a spring loaded pin which locked our arm to keep it from falling out. This meant no matter what, after the robot comms were disconnected our arm locked. We used a spike to control the solenoid.
Unread 08-12-2012, 21:40
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Generally I've just seen pneumatic solenoids, and used for controlling pneumatics. Whether this means a claw (Logomotion), arm, or even "unconventional" methods such as stingers (Rebound Rumble), anywhere there's a pneumatic piston, there's generally an accompanying solenoid.
Academic Student (Forever)
Unread 08-12-2012, 22:56
FRC #2537
@CalTran
Do you know of any FIRST team that's used a solenoid not on pneumatics? I was studying my team's robot from Logomotion, and while the gripper worked nicely, I think it could have been improved. I looked up solenoids and found they LOOk like they could be perfect for the job. However, our team generally tries to stay away from pneumatics unless there is a very good reason to do so. If this is the time, though, I would be open to it.
Unread 08-12-2012, 23:17
Originally Posted by MICHAELABICK View Post
Solenoids are illegal to use on an FRC robot for anything other than pneumatics
They were, through the 2011 season, that I can recall.
The 2012 rulebook, however, includes the following:
[R46]
Each power-regulating device (speed controller or relay module) shall control one and only one electrical load (motor, actuator, electric solenoid, or compressor).
[R48] J. electrical solenoid actuators, no greater than 1 in. stroke and rated at no greater than 10 watts continuous duty
at 12V,
Also see [R50].
Now, as to what the 2013 rulebook has, I'm as in the dark as you are, so we'll see if they're legal or not.
Unread 08-12-2012, 23:18
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The 2012 Rebound Rumble manual begs to differ.
[R48] The only motors and actuators permitted on 2012 FRC Robots include:
at 12V,
Do note that this rule was new in 2012 and is not guaranteed to reappear in 2013.
That being said, to answer the original question, solenoids are generally used to toggle an actuator between a discrete number of states (in FRC, this is always two).
In FRC, there are a number of situations where a linear solenoid actuator can be used (although whether such a solution would be permissible under the rules is not always clear, given the power restrictions on such solenoids). It can be used to shift gears. It can lock and unlock a mechanism. It can serve as the trigger mechanism for an appendage.
More commonly in FRC however, solenoids are used within pneumatic systems, to switch the direction of airflow.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 12-12-2012, 01:07
aaron2 aaron2 is offline
aaron2 is an unknown quantity at this point
you'll need to fabricate some kind of spring to pull the shaft back out after the solenoid pulls it in. in this tutorial i just wrapped some insulated wire around the shaft to create a make-shift spring
Unread 12-12-2012, 11:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Outside of valves solenoids provide relatively short linear motion. Think of them as a really small pneumatic cylinder. So to use them on an FRC robot.
1) You need an application where a short linear motion would be useful. Locking pins, shifting transmission gears, setting/releasing brakes come to mind.
2) You need to find a solenoid that fits the application & rules.
3) You need to design brackets & attachments to fit the solenoid into the mechanism.
4) In 2012 rules the solenoid would be wired to the control system through a Spike relay.
