Go to Post So now my family thinks I'm insane. - Amanda Morrison [more]
Unread 16-01-2003, 16:27
Goya Goya is offline
#0019 (Big Red)
Goya is an unknown quantity at this point
Send a message via AIM to Goya
Do ... Until ... Loop
The syntax I used for a Do .. until ... loop -
Do Until (sFront = 0)
'code
Loop
This creates an infinite loop that I cant get out of, even if sFront = 0. What gives?
In fact, I also tested to see if the value of sFront isn't changing with -
If sFront = 0 then DEBUG "Im Trapped, Help Me!",CR
Loop
This debugs "Im Trapped, Help Me!"
Thanks in advance,
Unread 16-01-2003, 16:48
#0019 (Big Red)
Actually, I have a more specific question. As I was reading the documentation that came with PBASIC 2.5 I noticed that the Do ... While ... Loop needs a condition with the WHILE and UNTIL, whereas statements are used where the code is inserted.
Do While|Until conditions
'code
statements
Loop While|Until conditions
Question - What is the difference between a condition and a statement ? Can I use sFront = 0 as a condition?
Thanks again,
Unread 16-01-2003, 16:56
#0019 (Big Red)
Hey, I figured out why the code was not working to my liking. In my code, I used a SEROUT, but no SERIN. Remember, you need to use a SERIN to get input from the sensors! This goes to show what sleep deprivation does to people!
Unread 19-01-2003, 01:16
maDGag maDGag is offline
maDGag is an unknown quantity at this point
perhaps, ur reassigning
sFont = 0 everytime u loop
mayb im wrong, how about some logical operators instead /
sFont == 0
meh ... forget me ... im still stuck in C++
Unread 19-01-2003, 02:46
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
No, == is not a valid operator in PBASIC.
Goya's third post hit the nail on the head: if you don't SERIN, you don't get any new data.
As for what makes an expression a condition is the presence of any of the following operators:
Note that = can also be used for assignment. It's function is determined by the context in which it is used. For example:
if rc_sw1=1 then ...
uses = as a comparison operator, whereas
rc_sw1=1
uses = as the assignment operator.
Unread 19-01-2003, 09:52
Hendrix Hendrix is offline
#0538 (Dragon Slayers)
Hendrix is an unknown quantity at this point
(sFront = 0)
that should just be sFront = 0
also before the main programming loop you should put sFront = 0 or something like that to tell pbasic what the value for it is...
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
How long is one stamp loop yangotang Programming 3 23-01-2003 20:36
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Counter loop archiver 2001 3 24-06-2002 00:44
OK...so I'm totally out of the loop... Markfuscius 3D Animation and Competition 8 03-02-2002 02:39
