Go to Post There really is nothing else that needs to be said. - billbo911 [more]
Unread 09-12-2012, 18:21
FRC #1836 (MilkenKnights)
Re: Drivetrain Concept - Help
The bearing load should be fine. Teams normally put the whole weight of their robot on 8 bearings, which is 15lbs per bearing. Way more than the weight of the gearbox.
A better solution may be to brace the two gearboxes together however.
