Go to Post "There's plenty of room on the top for everyone" ... it's not a top if everyone is there. - Alyssa [more]
Go Back   Chief Delphi > Announcements
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
  #166   Spotlight this post!
Unread 09-12-2012, 23:31
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: VEX Robotics Relaunches VEXpro Product Line with over 120 New & Improved Products
Originally Posted by JVN View Post
4. Yes, the hexes will all be aligned with the VersaKey pattern in a common configuration. Mounting multiple hubs on the same wheel will "just work."
-John
All,
I've been updated on this -- though this was our original intent, it proved cost prohibitive to do this. The hexes and VersaKeys will NOT be consistently aligned.
-John
  #167   Spotlight this post!
Unread 09-12-2012, 23:37
AdamHeard's Avatar
Lead Mentor
All,
-John
IF this is the case, what is your recomended method for mounting a 4x2 traction wheel live axle. A single hub?
  #168   Spotlight this post!
Unread 09-12-2012, 23:39
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
All,
-John
John, Now that the hexes and Versakeys will not be consistently aligned, how would you recommend doing the following:
(Picture is of a gear being used on one side of a wheel, versakey on the other, just in case the photo gets removed/updated to reflect changes)
Would you replace one of the hex hubs with a bearing hubs and then rely on the gear's hex and VersaKeys to transmit Torque?
-Dustin Benedict
Last edited by thefro526 : 10-12-2012 at 00:04. Reason: Don't type while half asleep. You'll forget words and letters on the end of words.
  #169   Spotlight this post!
Unread 09-12-2012, 23:40
Andrew Lawrence
Posts: n/a
Do you plan on releasing different sizes and widths for the VersaWheels?
  #170   Spotlight this post!
Unread 09-12-2012, 23:51
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
When will the CAD model of the Single Speed, single reduction transmissions be available?
Last edited by nahstobor : 10-12-2012 at 00:06. Reason: Single speed, single reduction
  #171   Spotlight this post!
Unread 09-12-2012, 23:54
JVN JVN is offline
@JohnVNeun
A single hub is more than enough to transfer the torque. So I would recommend a single hub, and a hex bearing for piloting on the other side.
  #172   Spotlight this post!
Unread 09-12-2012, 23:57
JVN JVN is offline
@JohnVNeun
Not for this season. We made the VersaWheel in a very universal size which we thought teams would use -- for other sizes we have the traction wheels:
http://www.vexrobotics.com/vexpro/wh...on-wheels.html
  #173   Spotlight this post!
Unread 10-12-2012, 00:00
JVN JVN is offline
@JohnVNeun
Would you replace one the hex hub with a bearing hub and the rely on the gear's hex and VersaKeys to transmit Torque?
Yes, that's exactly what I'd do. The single gear is more than enough to transmit the torque. You may just need a pilot on the other side, depending on the width of the wheel.
-John
  #174   Spotlight this post!
Unread 10-12-2012, 00:11
Aren_Hill's Avatar
Build Nifty Things
Turns out a 1/2" hex bearing on the other side to pilot is more cost effective than another hub anyways.
A guy who likes robots.
  #175   Spotlight this post!
Unread 10-12-2012, 03:01
President, VEX Robotics, Inc.
The hub designs are such that only one side needs a Versahub to transfer the torque. We initially intended that the hex would be timed to a certain VersaHub feature, but we quickly realized that we could not meet our pricing targets with such a requirement so we relaxed the requirement.
Our reasoning for relaxing the requirement was that since the full torque load could be taken by one hub, then a hex bearing can be used on the other side if you are worried about deflection. As it turns out, the bearing solution is less expensive for the customer anyway.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #176   Spotlight this post!
Unread 10-12-2012, 11:16
AdamHeard's Avatar
Lead Mentor
Paul
Thanks. I wasn't worried about torque, but supporting the shaft on the other side. For some reason I thought the wheel bores were 1.25, not 1.125. What you and John suggest is a really clean solution, I like it.
  #177   Spotlight this post!
Unread 10-12-2012, 11:35
Jared Russell's Avatar
Taking a year (mostly) off
It's also a great use for the handful of seized hex bearings we have collected through the years.
  #178   Spotlight this post!
Unread 10-12-2012, 11:45
JVN JVN is offline
@JohnVNeun
A few people asked about whether we would sell the shifter shafts independently. The answer is "yes" and they're already live on the site (linked from the kit contents section of the Ball Shifter page).
Short Output Shaft (w/ gears) -- as used in the 3-stage gearbox.
http://www.vexrobotics.com/vexpro/ge.../217-2793.html
Without gears... just the shaft:
http://www.vexrobotics.com/vexpro/ge.../217-2791.html
Long Output Shaft (w/ gears) -- as used in the 2-stage gearbox.
http://www.vexrobotics.com/vexpro/ge.../217-2792.html
http://www.vexrobotics.com/vexpro/ge.../217-2790.html
-John
  #179   Spotlight this post!
Unread 10-12-2012, 12:42
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
All,
-John
Does this apply to the 1/2" keyed hubs as well? I am assuming so but wanted to confirm anyway.
  #180   Spotlight this post!
Unread 10-12-2012, 13:07
JVN JVN is offline
@JohnVNeun
Yes, this applies to those.
