Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 10-12-2012, 08:25
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Bearing Blocks vs. Idlers
As a side bar, apalrd & BJC learned a very important lesson in their testing.
Some design for top speed. Some design for acceleration.
Time to distance though can be key in some games (pick and place games).
For shorter distances, acceleration is more important. For longer distances top speed might be more important. We initially started the season with an emphasis on top speed assuming full field width runs (about 24 feet) and full field length runs (about 50 feet). In reality, with the barrier in the middle slowing you down, and the fact that you typically went from 1 side to the middle, the typical sprint was more in line with 10-15 feet. Because of this (and other reasons), the guys regeared for MSC and the Championship to accelerate better.
