Go to Post As I told my friend Joe Johnson, just because you aren't around as much doesn't mean that you can just close the book on this chapter, instead - just keep a book marker in this place, so you can remember how to find your way back home - when the time is right. - meaubry [more]
Unread 15-01-2003, 16:11
jluvera jluvera is offline
jluvera is an unknown quantity at this point
Test Autonomous Mode
We have fitted last year's robot with the new RC and are using the new OI so we can test while others build.
In reading the default code, I see that there is a value read in for PB_mode. Basically, I am not sure how we can test the robot in autonomous mode since we don't know how the PB_mode variable is changed. The reference guide says to set the Team number on the RC to zero. That doesn't make sense to me because I thought that number needs to be set to our team number for the competition.
I would appreciate any help.
John Luvera
Team 637
John Luvera
Team 637
Unread 15-01-2003, 16:35
FRC Key Volunteer Trainer
AKA: CrazyNate
Take a look on IFI's web site under the Documentation section...there's instructions there as to how to create a new dongle which will let you switch autonomous mode on/off...
Nate Smith
nsmith@smythsoft.com
Unread 15-01-2003, 16:42
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
autonomous mode is aliased as auton_mode in the code...
here's some code to try:
if auton_mode = 1 then do_auto_stuff
'driver code here
goto end_of_auto
do_auto_stuff:
'auto code here
end_of_auto:
put that in the main loop...
it's really basic and has no real value unless you have code to put in there...but it should help out a little
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 15-01-2003, 17:31
You can still test your auton_mode code.... even with no Dongle.
Just set auton_mode equals 1 at the start of each loop, right after the serin. In your auton_mode service area, set the variables which are digital to zero, and the analogs to 127.
Jump from the auton_mode servicing part to the Serout or to the tank drive in the USER program, so that the rest of the program won't process the auton_mode values, and let things go. If your robot resembles a hairy rabbit, pull the plug.
Make a dongle soon, though. It's fun to watch the auton_mode switch from 1 to zero when the comp_mode (Kill switch) switches from 0 to 1.
Unread 16-01-2003, 17:22
rosebud rosebud is offline
#0115 (MVRT)
rosebud is on a distinguished road
one idea is to utilize the new code. use #if and #endif to only compile and download the autonomous code or the usercode. u can make the condition a #define statement or constant that u change whenever u want to test code. of course, this wont allow u to download auto and user code and switch without dowloading again, but at least u can test code. anyone know how to download programs into slots on the rc and then run different programs in different slots? or how to free up memory that is needed in auto mode but not in user mode?
Unread 18-01-2003, 14:09
roninmedia roninmedia is offline
The Ronin
AKA: Brian Nguyen
#1068
roninmedia is on a distinguished road
Send a message via ICQ to roninmedia Send a message via AIM to roninmedia Send a message via Yahoo to roninmedia
Autonomous Mode can be turned ON by setting the RC to Team 0 (zero).
Unread 19-01-2003, 15:03
Neal Turett Neal Turett is offline
Neal Turett is on a distinguished road
Work-around
Before we built a dongle, I just took an extra var (size = 1bit) and initialized it to 1. Then i'd have:
autom = 1
MainLoop:
if autom (my var) = 0 then endauto
if p1_sw_top = 1 then endauto
goto endmainloop:
autonomous code....
endauto:
autom = 0
normal code....
endmainloop:
serout(...)
goto mainloop:
That worked well enough, especially since it gave you a easily reachable kill-switch. Only thing to note is that if you use dead-reackoning, you need to tie the beginning of your autonomous code to another button, lest it run while the robot is disabled while the RC is not plugged in and your timer-count increase.
Unread 19-01-2003, 15:12
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Re: Work-around
The only problem with that is that button presses don't get sent to the RC, so it would never know about it. You are definately correct that you need a way to "start" your autonomous code, but this is best done by looking at the comp_mode bit, as its state will tell you whether you are disabled or active.
Unread 19-01-2003, 15:29
I was using this code before I had a dongle. The RC was always running in normal mode.
I would just flip on the bot, flip on the OI, and then hit the start button. It would still be sent. Otherwise, the robot would be counting pointlessly until the OI was flipped on, and you;'d get unpredictable results (like the robot running into a glass pane.)
Since the bot never technically entered autonomous mode, it still recieves data from the OI.
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
