Go to Post I wouldn't mind having this day repeat itself a few times. It would give us more time to work on our robot. - Mr.D [more]
Unread 06-12-2012, 13:13
279 EMPIE's Avatar
279 EMPIE 279 EMPIE is offline
Head Progammer
AKA: Matthew Empie
FRC #0279 (Tech Fusion)
279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice
Send a message via AIM to 279 EMPIE
Connecting two java programs with a Ethernet cord
I was wondering if anyone has made any code that will send information in a Java Program on a laptop through a Ethernet cord to the Program in the cRIO.
I'm sure it is do able its just i haven't found much sample code to learn off of. I have no experiance with programming IP/TCP, Ports, or anything else that has to do with this subject.
I was just wondering if someone could help me out.
2011- Programmer, Electrical, and Web
Cleveland Regional
2012- Head Programmer, Web, Driver
Pittsburg Regional, Saint Louis International
2013- Head Programmer
Cinnicinatti Regional, Taraho Regional
Unread 06-12-2012, 16:53
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Connecting two java programs with a Ethernet cord
I'd recommend making a SmartDashboard plugin to serve your needs, and use Networktables/Networktables2 to pass the data. That way you really don't even need to bother with handling TCP/UDP directly.
What are you doing with the data at either end?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 07-12-2012, 14:04
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
Well i would most likely be transferring Variables and Numbers from the Laptop to the cRIO.
Cleveland Regional
Unread 07-12-2012, 15:10
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
I would definitely recommend saving yourself a lot of trouble and use the SmartDashboard. It can do that without a problem.
All opinions are my own.
Unread 07-12-2012, 18:15
F22Rapture's Avatar
AKA: Daniel A
Exactly. You don't even need to use a plugin since networktables has that functionality built in.
- Wernher von Braun
Unread 10-12-2012, 13:40
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
Talking Re: Connecting two java programs with a Ethernet cord
Thank You,
I have never used SmartDashboard before so i will look into that and see what i can do.
Cleveland Regional
Unread 11-12-2012, 12:21
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
Does SmartDashboard have a API??
Cleveland Regional
Unread 11-12-2012, 12:28
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
http://www.wbrobotics.com/javadoc/ed...Dashboard.html
Unread 11-12-2012, 13:13
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
TY
Cleveland Regional
Unread 11-12-2012, 13:52
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Note: SmartDasboard 2/NetworkTables 2 will be coming out for the 2013 season. Make sure to upgrade when it arrives!
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 11-12-2012, 17:36
F22Rapture's Avatar
AKA: Daniel A
Actually, it's SmartDashboard 3
Has anybody managed to figure out how NT2 works, exactly? I'm sure it's much more efficient than NT1 but it also seems a whole lot more complicated. We don't have a robot to test on atm so I really couldn't mess with it much even if I wanted to.
- Wernher von Braun
