Go to Post But when it comes down to it, the best teams usually end up winning regardless. - Cory [more]
View Poll Results: Use it or not
Yes 84 87.50%
No 12 12.50%
Voters: 96. You may not vote on this poll
Unread 11-12-2012, 16:27
Bob Steele's Avatar
AKA: Bob Steele
Re: VEX PRO. To use it or not to use it.
Originally Posted by Tristan Lall View Post
It sounds like they're using ordinary Teflon-impregnated anodizing. Aluminum oxide, (a.k.a. alumina, Al2O3, carborundum or sapphire) is a ceramic, although it is somewhat unconventional to describe it as such in these circumstances.
I doubt very much that they're using a flame-sprayed ceramic coating. (What would be the point, and how do you apply Teflon at those temperatures?)
Interestingly, they're apparently applying the coating after machining, given the claims of reduced friction (application after machining also tends to contraindicate a flame-sprayed ceramic in this application). Most high-quality anodized aluminum gears are made from 2024, and anodized before the teeth and bores are finished (i.e. the cut teeth are bare metal).
JVN was joking.....read above...
