Go to Post Your wheels look delicious. - Alexa Stott [more]
Unread 11-12-2012, 21:15
Andrew Lawrence
Posts: n/a
3-motor transmissions
Based on a topic brought up in the "Why not shift" thread (http://bit.ly/UgKdrg)
With the new Vex 3-motor, single-speed gearbox, something I've been looking into is why certain teams have or have not used a 3 motor transmission, and the logistics of such.
Here are some of my main concerns:
1) Have you used a 3 motor transmission in the past before?
If no, why not?
If yes, why did you want one? Do you think it was worth the extra work? Did you have any problems? Was it a shifting transmission or a single speed?
2) What kind of motor would you use in the 3rd motor slot? I've heard a lot about teams ditching their 3rd motors due to burning them out too often. How is this caused, and what precautions can be taken to prevent it?
3) What kind of wheels did you use with the 3-motor transmission? Did they work into a strategy used with the 3-motor transmission? Had you had a 2 motor transmission would you have used different wheels? When in the design process did you decide to use a 3-motor transmission?
4) Last but not least, what other advice would you have for a person looking into using a 3-motor transmission?
Thanks!
Unread 11-12-2012, 21:20
ttldomination's Avatar
Sunny
Re: 3-motor transmissions
If no, why not?
I'll add this one because, in short, this is the only experience I've had.
The short answer to this simply the fact that there wasn't a resource available that provided us with this capabilities.
One of my mentors always believed in using everything that gives us power in the kit. If we didn't have a PDV from AM, I'd pick up one of the VEX gearboxes and cross my fingers that we'll get a chance to slap six motors onto the DT.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 11-12-2012, 21:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
3 motor shifting in 2005 with 696. Didn't really need nor using. Not a smart decision.
3 motor shifting in 2008 Overdrive with 968. Worked fantastic, but we ended up changing the robot design, and borrowing two motors off the drive. Robot accelerated noticeably slower without them. Geared for around 21 fps top speed that year.
3 motor single speed in 2012 with 696. Worked great. Geared for pretty good speed, gave extra torque to get over the bump, push robots up bridge, etc. Never a problem.
Unread 11-12-2012, 21:29
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Your 2012 bot certainly looked good moving around on the field. What third motor did you use?
Edit: nevermind http://www.team696.org/history/index.php?qhr
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 11-12-2012, 21:30
Billfred's Avatar
Billfred Billfred is offline
2815 (and 1398) used a six-motor shifter in 2010; our design had the motors available, so why not?
We used two CIMs and an F-P with the AM Planetary on each side. No issues with either. AM Plactions were the wheels, with roughtop.
In hindsight, it was overkill for our one-zone strategy...but it also didn't harm things either.
Unread 11-12-2012, 21:33
FRC #1836 (MilkenKnights)
The three teams that I know of that used 3 motor gearboxes were 33 2012, 973 2011, and 254 2012(I'm sure there are a lot more, these are just the ones I know of off the top of my head).
1) I know 973 ran into problems with their 3rd motor because it was a 775(case short problem). I've heard that if they were to do it again they would use a 550 instead. Not quite sure if 254 or 33 ran into problems. I know 254 and 973 ran theirs off their WCD shifting gearbox. IIRC 33 ran theirs off an AM shifter. One of the things that I noticed was that 254 was able to gear higher this year because they used a 3rd motor. According to their website, they geared over 20 FPS with a full weight robot, something that would have been unable to do otherwise(very slow acceleration).
2)Never heard of burning out motors. I'm pretty sure 254 and 33 ran a 550. I know 973 used a 775 later and regretted it after due to the case short problem.
3) 254 ran their normal wheels. Not sure about 33. 973 ran wider (2" wheels), though they ran these same wheels once they took the extra motor off. I know it allowed them to push most people, even with only 4 motors(they pushed 469). I don't know if they used 2" wide wheels specifically because they were running 3 motors per gearbox.
That's a brief overview of what I know about 3 motor gearboxes. I've never actually made/run a 3 motor gearbox, so take this all with a grain of salt.
Unread 11-12-2012, 21:44
Ravage457's Avatar
Ravage457 Ravage457 is offline
Ravage457
AKA: Jesus Jurado
FRC #0457 (Grease Monkeys)
Ravage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to behold
Does anyone have an Autocad drawing or pictures of this type of setup? Im curious to see it
FRC Team 457 "04-"05,"07-"08,"11-Present
Lead Drive Train Mentor/Drive Team Head Coach
2014 Dallas Regional Winners:#1 Alliance-Captain: 148, 1st:359, 2nd:457
2013 Hub City Off-Season Event Winner:#1 Alliance- Captain: 457, 1st:3366, 2nd:1817
2012 Alamo Regional Winner:#3 Alliance- Captain:231, 1st:1477, 2nd:457
2012 Ozark Mountain Brawl Winners:#8 Alliance - Captain:1986, 1st:1987, 2nd: 457
2012 Texas Robot Roundup Winners:#1 Alliance- Captain:118, 1st:624, 2nd:457, Backup:4332
Unread 11-12-2012, 21:47
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Check out team 254's website.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 11-12-2012, 21:53
Sunny
I think 254 rebuilt their website. Their image gallery has been unavailable for a while.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 11-12-2012, 22:02
Ravage457's Avatar
Ravage457
AKA: Jesus Jurado
- Sunny G.
Actually it back up, just saw it right now, thanks gregor
254 has rebuilt their website, so their gallery is empty. However they do have renders of their 2012 gearbox posted. In addition you can look through Patrick Fairbank's 254 Build album.
Unread 11-12-2012, 22:08
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
The reason why not is that it tends to be overkill in a lot of cases, and the motors that add a lot as a 3rd motor (BB775's, 550's and FP's) tend to be your best motors to use elsewhere. The DT motors tend to be abused a lot too, and that can have a detrimental effect on air cooled motors like the banebots and Fischer-Prices if they're not designed in right.
There are two main reasons you would want to do it:
1) You want to be traction limited but have a high top speed (>13 ft/s) with decent acceleration and not require a shifting gearbox
2) You have a shifting gearbox and want a really high top speed without an acceleration penalty (>17 ft/s).
Both of those speeds are rough rules of thumb based on a 150lb robot (inc. batteries and bumpers) running wedgetop tread. That's just how the math tends to work out. The main advantage you get from the extra motor is the acceleration and torque increase at higher speeds. It really has no effect on the low speed performance, provided you're still traction limited*.
Personally, I don't see many games where it's necessary, again going back to the motors that are used. They need to be fairly high power to have any noticeable improvement (remember, 2 CIMS is a pretty beastly drivetrain already). I would argue that for the vast majority of teams, it's more worthwhile to go 6 motor driveline to get rid of shifting than to get that extra jump from 17 ft/s to 20 ft/s, but each team has to make that call. If the majority of your robot mechanisms are going to be pneumatic, then it's less of a sacrifice.
Don't forget to think about your robot from an entire system standpoint. While it might be great to zip around the field at 20 ft/s, if your arm take 3 seconds to score an object because all you had left were window motors, you might actually be taking longer to score than if you'd left your robot at say 15 ft/s, but take only 0.5 second to score.
254 has used 3-motor transmissions several times, although very few have been successful. I recall their 2005 (and maybe 2006?) drivetrain had FP's as the 3rd motor, and they burned several of them out. In 2012 they intended to have three motors (BB775's IIRC), but ended up reallocating them to other robot functions, and changed their gearing to a lower top speed to account for this.
*I would never, EVER recommend designing a drivetrain that isn't traction limited in it's lowest (or only) gear. That's a great way to burn out motors and blow breakers when you run into robots and walls. 3 motors will NOT make you stronger in a pushing match.
Unread 11-12-2012, 22:33
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
A 3 motor 3 position shifting transmission could be used for a number of things. The third motor could be shifted to a winch or roller pulley for example(power take off) and still have your main drive working. But if you needed the extra turbo power the transmission could shift the third motor to the drive train gear. Couple that with a electrically actuated disc brake and a over current protection sensor and we have something pretty darn cool.
I hope this years game is a racing game with full size robots climbing poles at end game aka minibot style
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 11-12-2012, 22:43
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Is there anywhere one can find some in depth information about how an FRC power take off would work? I know there are teams who have used them, IE 1114 in 2010, but I've never been able to find a paper or an explanation or a CAD of how they work.
Academic Student (Forever)
Unread 11-12-2012, 22:49
For a PTO, look at 254/968 in 2010. It was basically another shifting setup. Another piston and another dog and dog gear.
The first PTO I saw in FIRST was on Team 60 in 2004. Amazing mechanism they had.
