Go to Post If you speak three languages, you're trilingual. If you speak two languages, you're bilingual. And if you speak one language, you're American. - Hieb [more]
Unread 11-12-2012, 21:47
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Re: Battery Chargers
Originally Posted by alb4h View Post
How many batteries do your teams take to competition?
Ann
We typically cycle them after every match. Around 8 total.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 11-12-2012, 21:52
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
We have around 9. We also cycle them every match.
Keep in mind every rookie will get 2 batteries, and every veteran will get 1.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 11-12-2012, 21:53
dcarr's Avatar
#HoldStrong
AKA: David Carr
Going on precedent, but without the 2013 KoP list we don't actually know for sure...
Team 3309
Team3309.org
Unread 11-12-2012, 21:58
Gregor's Avatar
http://www.chiefdelphi.com/forums/sh...90#post1200890
<Since 2011
Unread 11-12-2012, 22:01
Do not try to charge batteries in parallel please. I asked this question of MK and The Battery Association of America (I think that was the name) and both responded that the only way that was acceptable was if the batteries were all purchased at the same time, had been charged the same and had the same loads applied over their lifetime. And then it may work or it may damage all of the batteries. In other words if the batteries were assembled into a larger array and only used that way could other methods of charge and discharge be used. These batteries are not like the large arrays used on electric subs or in large UPSs where the acid is checked regularly and specific gravity is monitored cell by cell.
The best way to test batteries is to use an analyzer like the CBA III from West Mountain Radio. when they can no longer supply more than 15 amp hour, I would move them into the practice pile. When they fall to 10-12 amp hour, then it is time to recycle. If one cell dies before the others, recycle immediately, that cell is likely damaged internally. The Battery Beak from Cross the Road Electronics should also indicate when to remove the battery from competition.
Unread 11-12-2012, 22:03
dcarr's Avatar
#HoldStrong
AKA: David Carr
Thanks! Missed that.
Team 3309
Team3309.org
Unread 11-12-2012, 22:11
Gregor's Avatar
I aim to please.
<Since 2011
Unread 11-12-2012, 22:58
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Ann
We bring 8. Enough for testing, matches and loaning.
Wetzel
Viva Olancho!
Unread 11-12-2012, 23:42
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Originally Posted by Tristan Lall View Post
(Are you sure that NS18-12 is even a valid part number?)
Quick correction, last years rules specified the NP18-12 which is also an AGM design.
Typo on my behalf, I was referring to the NP18-12. Sorry!
The charger shown above can be used but I would not recommend (nor was it legal in 2012) to charge at 8 amps.
We won't be getting the BatteryMINDER, but if we had my intent had been to run it at 4A, not 8A. I understand and see the reasoning behind your perspective that 6A is a purely nominal maximum setting, but I still can't help but be mildly uncomfortable charging batteries rated for max charge currents of 5.1A and 4.3A at "6A" (let alone 8A!)
Originally Posted by Joe Ross View Post
The problem with charging batteries in parallel from a single output is that each battery is in slightly different condition and state of charge. They try to work around this by giving the following conditions in the manual. I don't trust that you could ever guarantee this, so I don't think it's safe.
Additionally, notice that this is only to maintain the batteries, once they are fully charged. It won't charge 6 batteries.
I thought as much - I was rather skeptical of the method when I noticed it, because I just couldn't see charging them in parallel as a safe method, given that batteries often tend to differ from unit to unit. Thanks for confirming.
Originally Posted by Michael Hill View Post
Another related question...how many years do other teams use the same battery? It seems like after just a couple years of competitions, we've got some batteries that are bad. It can't help charging at such a high charge current during the days of competition (we have maybe 8 batteries total on our team?)
We buy a new batch of batteries every year, since most of our robots tend to err towards ridiculous power consumption. Our competition batteries tend to consist of mostly ones we buy that year, supplemented by ones from the previous two years that have good max charge records (we made a simple battery tester in-house that displays the battery voltage measured across a small load on an LCD screen; a "good" max charge record, with reference to our usage, tends to mean that it consistently charges up to 12.5V or higher).
Ann
We bring 8 with us. During qualification matches, we'll often have as many as 3 at full charge (the rest are either charging, in the robot for practice/testing/matches, or being used for auxiliary 120VAC through an inverter), but we make sure every battery is fully charged (or as many as possible) going into elims, because of the rapid turnaround time between matches.
Thanks to everyone for the outpour of feedback
I'm still curious if anyone has found success with alternatives to the Schumacher and Dual Pro. Speaking of which, it seems that Dual Pro makes an IS3 along the RS3, but I can't seem to identify a difference between the two...
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 15-12-2012, 19:16
DonRotolo's Avatar
Back to humble
FRC #0832
Our batteries last 2 or 3 seasons generally, sometimes more. It is critically important to keep them fully charged, even over the summer, since A) they are damaged by sitting even a little discharged and B) they have a self-discharge that requires charging every 60 days or so.
We have 10 to 12 batteries we bring to competition.
Unread 20-12-2012, 01:38
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
My team usually ends up buying 2-4 batteries each year. We use the best ones at competitions and relegate the older ones for practice or shop testing.
After a team accumulates a lot of batteries, keeping track of their age and condition is a chore. I have ours labelled and we keep a log at competitions. We are careful to use them in sequence, so that the last one used gets to charge and rest while all the others are used. Every battery is labelled with a number and we follow that sequence.
We test every battery once at the beginning of the season on a West Mountain CBA-III. It's a wonderful device which gives a real picture of the battery's condition, but it is time-consuming, often more than an hour per battery.
This year, we are considering buying fresh batteries for competition and calling everything from previous years either practice batteries, or recycling. You can get through most regionals with 6 batteries as long as they are good ones. Use a fresh battery for every match - never more than one match. You have enough time to charge the battery from your first match well before you reach a seventh match.
Put one person on your pit crew in charge of batteries so that they always know what is going on with them. Have them keep a log on a clipboard to track what time the battery went on the charger and when it came off. Analyzing these logs later can identify both weak batteries and defective chargers.
We have a battery manual for the team and review it with the entire team once a season. It covers everything from theory to handling to use and charging to spill procedures and recycling. A copy is kept in the pits for reference.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 10-01-2013, 13:24
Happy Birthday! shawnliner shawnliner is offline
FRC #3753 (BulahBots)
shawnliner is an unknown quantity at this point
Does any one have a solution to running the robot from A/C power? A A/C to 12V converter that's safe for the circuitry.
I seem to recall seeing one on AndyMark, but I can't find it now. This would be handy for programming and imaging.
Thanks
Shawn Liner
Coach
Team 3753
When I learn, I win. If I can win too, that's gravy.
Unread 10-01-2013, 13:53
How much of the robot do you want to run?
A simple 12 volt power supply at a few amps will handle the control system and sensors. You can do a lot of software development that way. It's probably best to use a linear supply, as a fancier "switching" power supply is likely to balk at the boost regulators in the Power Distribution Board.
Motors are another thing entirely. If you want to be able to supply the same kinds of current you can get from a robot battery, you'll end up with something huge, heavy, and expensive.
Unread 12-01-2013, 03:36
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
We started using these chargers last year after suffering with poor performance from past and present kit chargers, we were loosing them 1 by one.
http://smartercharger.com/products/b...-multi-us-4-3/
Our new battery cart with 6 of those things with all their LED's glowing on the front sure generated a lot of attention at the AZ regional last year.
It's the only charger I will use on small backup generators, and battery backups now too.
We also load tested and purged all of our old and failed batteries and got fresh ones so now we roll with 12 good batteries and 6 good chargers.
Unread 14-01-2013, 07:38
Batteries or chargers? The charger shown appears to be a nice alternative.
