Go to Post 100% of the robots on Einstein in 2009 had hard plastic wheels for their drive train. - efoote868 [more]
View Poll Results: Use it or not
Yes 84 87.50%
No 12 12.50%
Voters: 96. You may not vote on this poll
Unread 12-12-2012, 02:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: VEX PRO. To use it or not to use it.
Originally Posted by Tristan Lall View Post
I'm basing that mainly on the high-quality fine-pitch aluminum gears available from SDP/SI and PIC Design, and those gears I've observed in random precision machinery. (So "most" isn't strictly the right descriptor—more like "most of the ones I've encountered".) Those ones are quite noticeably machined after anodizing (plus it says so in the catalogue).
As for galling, in a normal atmosphere that will oxidize the bare surface, at least there's some protection. I don't know if the tooth-to-tooth contact stresses are high enough to break through the natural layer of oxide and promote galling.
So...it's a cosmetic surface finish?
I don't understand why you'd anodize the gear if you're going to machine it away at the only point where it matters.
2001-2004: Team 100
2006-Present: Team 254
