Go to Post I have a pocket full of Gracious Professionalism! How about you? - Schnabel [more]
Unread 12-12-2012, 12:45
Cronus4304 Cronus4304 is offline
FTC #4304
Cronus4304 is an unknown quantity at this point
Programming the Hi Technic Force Sensor
Our team has a great idea for integrating a force sensor into our robot, however we are not sure exactly where to locate the proper blocks in LabView. Does anyone have experience in LabView with force sensors?
Unread 13-12-2012, 09:53
Re: Programming the Hi Technic Force Sensor
If a sensor produces an analog voltage, connect it to the Analog Breakout and use the Analog Input functions to define and read it.
You're talking about the NXT Force Sensor (NFS1074), right? Its output is a voltage that represents the amount of force pushing on the sensor.
Unread 13-12-2012, 17:25
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
''The Force Sensor is an analog sensor like the LEGO Light Sensor. Therefore the same way you read the LEGO Light Sensor can be used to read the Force Sensor value.''
Source: http://www.hitechnic.com/cgi-bin/com...on&key=NFS1074
Hope this helps!
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
