Go to Post Stop making me want to spend money on books! I don't need any more good influences in my life!!!! - FourPenguins [more]
  #196   Spotlight this post!
Unread 12-12-2012, 08:55 PM
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: New Talon Speed Controller
Originally Posted by Joe Ross View Post
The 2012 LabVIEW CAN Library implemented an isochronous mode. It does not block, but also doesn't look for the Ack. It's designed for sending periodic updates where you don't care if a particular message is received. There's a boolean input for whether you want isochronous or blocking.
I see the isochronous mode for the Motor Control Set, but nothing else.
I also see that Read Status sets a timeout of 0 for messages continually transmitted, but could also do a transaction (with 10ms timeout) if requesting something on-demand.
Everything else is still blocking (set parameters require Ack, read parameters are synchronous).
Really, CAN is designed to never care if a message is received, and to transmit everything continuously (with less important information at a slower rate). Having an Ack message makes no sense to me.
Edit: Motor Set defaults to synchronous mode, and the Isochronous input is not in the help. I'm guessing many teams still run in synchronous mode. It should default to isochronous mode, IMO.
Kettering Motorsports
  #197   Spotlight this post!
Unread 12-12-2012, 11:51 PM
Is it possible to revert a Talon to factory calibration?
  #198   Spotlight this post!
Unread 12-14-2012, 03:17 PM
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
No it is not.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
  #199   Spotlight this post!
Unread 12-14-2012, 03:33 PM
Originally Posted by Mike Copioli View Post
No it is not.
Mike, could it be done with a PWM signal generator which generates a known pulse width accurate to 0.001 ms ?
  #200   Spotlight this post!
Unread 12-14-2012, 03:55 PM
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Mike, our last Beta update included a new class for the Victor 888's. I haven't seen one for the Talon yet.
Is one going to be released? If not, what's the recommended class to use? We haven't had any problems using the victor class with it at all.
  #201   Spotlight this post!
Unread 12-15-2012, 12:33 AM
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
We're not in the beta, but I changed my plugin source to the beta channel to ensure compatibility with older code, and as per today's update:
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
  #202   Spotlight this post!
Unread 12-15-2012, 03:17 PM
Tom Line's Avatar
Figures. We're now one update behind because we had our seminar and didn't want to break our code by updating a day or two before the seminar. It's probably in there.
  #203   Spotlight this post!
Unread 12-16-2012, 09:40 AM
No. Joe's questions was regarding factory calibration. These settings are what the firmware saves to flash when the Talon is first programmed. These settings are over written once the user performs a successful calibration.
A user calibration could be performed to obtain values that are are close or even the same as what's saved during initial programming. But there would be no way for the user to confirm this.
We did not feel the ability to restore factory calibration was necessary since the procedure would not be much different than performing a user calibration. And a user calibration will yield the best performance.
Mike Copioli
  #204   Spotlight this post!
Unread 12-18-2012, 12:10 PM
nerdherdmember's Avatar
nerdherdmember nerdherdmember is offline
#letsdothis
AKA: Harrison (That kid with the blue hat)
FRC #0422 (Mech Tech Dragons)
nerdherdmember is a jewel in the roughnerdherdmember is a jewel in the roughnerdherdmember is a jewel in the roughnerdherdmember is a jewel in the rough
FRC 422 just received the first 8 of our Talons! They are far smaller than we imagined them to be.
  #205   Spotlight this post!
Unread 12-18-2012, 02:40 PM
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Team 2410 put four on our mecanum demo robot and man do they drive like a beauty! Makes driving off of our app so much smoother and easier. Me gusta mucho.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
  #206   Spotlight this post!
Unread 12-18-2012, 03:20 PM
Compared to what? (also, what does "off of our app" mean?)
  #207   Spotlight this post!
Unread 12-18-2012, 03:29 PM
CalTran's Avatar
Missouri S&T Senior
Compared to previously having 4 victors. Off our app means we put one of the robot open shields on it and one of our programmers wrote an app too driver the demo bot off a phone with
  #208   Spotlight this post!
Unread 12-18-2012, 03:34 PM
Were you driving the Victors "off the app" too? ... so that you were comparing apples to apples?
  #209   Spotlight this post!
Unread 12-18-2012, 03:37 PM
CalTran's Avatar
Missouri S&T Senior
Yeah we were driving the Victors off the app as well. The Talons just seemed more responsive. I will admit it was not a blind study so maybe its just the hyper behind the Talons that makes it seem so
  #210   Spotlight this post!
Unread 12-18-2012, 03:48 PM
I'm thinking it's probably the linearity of the Talons which made the difference you noticed.
But as you said, it would be most interesting to conduct a blind study.
