Go to Post The 2008 team is not the 2007 team and won't be the 2009 team. Every year is a new year and a new opportunity for growth and development as a FIRST team. It's very cool. - JaneYoung [more]
Unread 14-12-2012, 15:22
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
pic: Team 1325 Custom Wheels
Unread 14-12-2012, 15:24
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1619
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
Re: pic: Team 1325 Custom Wheels
What's the diameter and weight? They look nice.
What's the weight on one of those? Looks quite heavy for a custom wheel.
Unread 14-12-2012, 15:43
Feroz1325's Avatar
Due to the teachers strike we don't have access to our shop or our scale, they are relatively light (we were a bid conservative with the lightening as its our first time), when I get a measurement I will post it.
They are 4 inches in diameter .
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 14-12-2012, 16:04
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
They are beautiful.
Akash is correct, though; custom wheels are often designed with less wall thickness to save weight.
I'll guess each of those is about 1.2 lb.
Richard Wallace
since 2003
Unread 14-12-2012, 16:18
Feroz1325's Avatar
In terms of reducing weight for a second iteration, what would you suggest? We were thinking of adding a shape between the sprocket mounting holes to reduce weight, anywhere else?
Feroz Balsara
Team1325.com
Unread 14-12-2012, 17:26
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Your spokes don't need to be the full 2" wide. You'll be fine with just 0.75"-1". That should shave of a good chunk of weight.
Unread 14-12-2012, 19:29
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Also other than just doing it because you can why would you go with these over the new vexpro traction wheels? If it was just an engineering exercise then great!
Mentor 2415
Unread 14-12-2012, 20:08
Feroz1325's Avatar
The wheels are part of our offseason prototype drivetrain. We wanted to try somethings we had never done before. As a mentor, I am very proud of the initiative the students took with the design. A student with only one year on the team designed and iterated this wheel through CAD and then worked with a sponsor to have them made.
We will be experimenting with them, as well as some vex stuff to find advantages/disadvantages.
Feroz Balsara
Team1325.com
Unread 14-12-2012, 22:34
Cool stuff! I like the integrated offset hub to mount sprockets.
Unread 14-12-2012, 23:00
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Have you thought about how to put tread on the wheel? It looks like riveting is your only option at this point, but you'll have to have some consistent method of drilling their holes. Another mill setup in a vise maybe?
Seconding what others said, these look very heavy. Don't just make the spokes smaller, also conciser pocketing it from the other side. Also, you might want to tap those sprocket mounting holes, so you don't have to it a nut on the other side.
-Plutarch
