Go to Post I think he GDC is just rick-rolling all of us. - z_beeblebrox [more]
Unread 14-12-2012, 20:34
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: numerical computation contest
Russ,
I understand you intended this one as a programming exercise -- hence you posted it in the programming forum.
However, it can also serve as an example of engineering approximation. Jon showed earlier how the Pythagorean theorem gives 51.48 ft as a rough approximation.
For a slightly better one, I used the Taylor series expansion for the sinc function, defined as sinc(x) = sin(x)/x. The first two terms of that expansion are:
sinc(x) = 1 - (x^2)/6 + ....
The arc length is 2rx and the chord length is 2rsin(x), where 2x is the angle subtended by the arc. Since the chord is one mile long and the arc is one foot longer, we have:
sinc(x) = 5280/5281
and the truncated series approximation above gives
x = sqrt(6/5281) = 0.03371 radians, or about 1.931 degrees.
Then the arc is part of a circle with perimeter
(5281/5280) x (180/1.931) = 93.23 miles,
so the radius r is 14.84 miles [this is a very flat arc!]
and the height h is 14.84 x (1 - cos(x)) miles = 44.49 ft.
Back in the day, engineers without benefit of cheap computers could have gotten this close using slide rules; i.e., four figures.
Richard Wallace
since 2003
Unread 14-12-2012, 21:21
Excellent post Richard.
You anticipated where I was going to take this.
ID:	13293  Click image for larger version
ID:	13294  Click image for larger version
Unread 14-12-2012, 23:23
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Ether,
I'm not a programmer, but I love a good geometrical challenge.
The equations I came up with were: (r-h)sin(l/2r)=x/2 and 2rsin(l/2r)=(x^2/4+h^2)^1/2
where r was the radius of the curve, h was the height specified in your diagram, l was the length of the curve, and x was the length of the chord. To find the numerical solution, input values for l and x, and solve for h or r.
Was the "challenge" to write a program that found the solutions of these functions through guess and check? Or did I come up with a different solution? Plugging in the values on this thread with my trusty graphing calculator, I got a reasonable approximation of the answers posted on this thread.
-Plutarch
Unread 14-12-2012, 23:28
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by DampRobot View Post
Ether,
Even getting a reasonable approimation is good enough, because there is no exact answer. I simplified until I ended up with a formula that looked something like this:
sin (theta/2) = (theta * Arc) / (2 * chord length)
With theta being the angle inside the two radii that would have gone from the center of the circle to the end of the cords.
That can only be solved iteratively, graphically, or by a lookup table (for those of us who remember not having calculators....)
Once you have theta, the height is trivial.
Unread 15-12-2012, 01:15
There is no explicit solution so you have to use iteration.
For folks like Christopher149 who know how to use modern math tools like Mathematica this is very simple to do, and you can get answers of arbitrary precision.
Mathematica is very expensive, but there are free CAS (Computer Algebra System) tools like Maxima which anybody can download and install for free. Maxima can also solve this problem with arbitrary precision (see my earlier post where I used Maxima to get 600 digits).
Attached are:
- The derivation of the equations
- A simple Delphi console app code which uses a binary search to find theta
If you replace sin(theta)/theta - 5280/5281 with a 12th degree Taylor expansion (see Richard's earlier post about Taylor expansion), you can squeeze out 16 decimal digits of accuracy with this simple code using Intel's X86 Extended Precision floats
ID:	13298  Click image for larger version
Unread 15-12-2012, 12:50
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
This reminds me of a chapter in one of my favorite books:
The History of PI
Specifically, you guys are reminding me of chapter 10, "The Digit Hunters".
I am very impressed. Happy hunting.
Unread 15-12-2012, 13:51
I think you made a mistake somewhere along the way. Those equations don't look correct.
x/2 = rsin(l/2r), not (r-h)sin(l/2r)
and
2rsin(l/r) = x, not (x^2/4+h^2)^1/2
Unread 15-12-2012, 17:30
Originally Posted by k4mc View Post
I believe the answer is 44.4984550191007992545541 feet
(although I used a "wolfram alpha method" , not an analytic one to solve the equation)
Sorry, I completely overlooked your post !
You were the first to get a correct answer.
Would you please post you work?
Unread 15-12-2012, 18:20
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
I don't think you overlooked it. There seems to be a delay in people getting their first couple of posts published when they are new to the forum. The awkward thing is those posts then sneak back into the list of posts in the spot they were written at. Easy to miss them completely if a lot of posts have been written in the mean time.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 15-12-2012, 18:51
Originally Posted by Alpha Beta View Post
...those posts then sneak back into the list of posts in the spot they were written at.
Aha. So I'm not losing my mind (yet).
Unread 15-12-2012, 21:41
That should be sin (theta/2) = (theta * chord) / (2 * arc)
Unread 16-12-2012, 18:21
Just for fun, here's a graph showing the behavior of the 2nd, 4th, 6th, and 8th degree Taylor approximations for the sinc function from zero to 3pi/2 radians.
Here's Maxima code to generate the graph.
Maxima is free software with an active and helpful mailing list.
ID:	13313  Click image for larger version
Unread 16-12-2012, 18:38
Just for fun, here's a graph ...
It would be interesting to see a graph comparing the 2nd, 4th, 6th, and 8th order expansions of 1 - sinc(x) plotted vs. x, for 0 < x < 0.05. The range of most interest will be near 1/5280 ....
I'd do it myself, but have been unable to locate Maxima as an iPad app (yet).
Richard Wallace
since 2003
Unread 16-12-2012, 20:19
... or 1/5281
sin(θ)/θ = 5280/5281 = 1 - 1/5281 => 1 - sin(θ)/θ = 1/5281
The Taylor expansions (even the 2nd degree one) are so accurate over the range 0<x<0.05 that you can't see the difference on the graph at that scale. Which maybe was your point
Also attached is the 64 decimal digit precision computation of θ using the zero of the function y = 5280/5281 - sin(θ)/θ and its Taylor expansions.
Finally, notice that the Taylor8 expansion actually gives a more accurate answer than the original function itself, when using only 16 digit precision. Presumably, this is because Taylor8 is numerically more stable.
ID:	13315  Click image for larger version
ID:	13316  Click image for larger version
Unread 16-12-2012, 21:11
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
This whole thread reminds me of an easy (for you all) geometry question. Imagine a sphere the diameter of the Earth. Add to that a belt around the equator that has no space between it and the surface of the sphere. By how much must the length of that belt be increased to allow a playing card to be slipped underneath the belt at all points along it?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
