#11
new rule
PAGE 20, RULE M17
This rule was drafted to attempt to prevent damage to our playing field, which includes the ramp structure, field borders, etc. Because we allow you to fabricate a wheel, it really doesn’t make much sense for us to say: “The outer surface of off-the-shelf wheels may be modified by removing tread material only.” Please delete this sentence; however, now we need to address the issue of “anti-traction” devices or anchors, i.e., devices designed to hold you firmly in one place. Anchors cannot use metal in contact with the carpet to “stay put.” Similarly, metal traction or anchor surfaces are not allowed on the ramp surfaces. Add the following to Rule M17: Anchors, i.e., devices that are deployed/used to attempt to keep one’s robot in one place and to prevent from being moved by another robot, cannot use metal in contact with the carpet to “stay put.” Similarly, metal traction or anchor surfaces are not allowed on the ramp or platform. so now you can add stuff to you wheels, or take it off, it's your pick. |
| Wheels or Treads | redbeard0531 | Technical Discussion | 21 | 13-01-2003 21:05 |
| Tank treads and specialty wheels | archiver | 2001 | 7 | 24-06-2002 01:25 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| TANK TREADS...welp. | archiver | 2001 | 13 | 23-06-2002 22:50 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
