Go to Post I might be a nerd, but I am definitely a pi freak! - Courtneyb1023 [more]
Unread 11-01-2003, 16:31
lj8758 lj8758 is offline
lj8758 is an unknown quantity at this point
Question tank treads vs. threaded wheels
which is better for the task at hand, having a tank tread system set up or a system of wheels in which the tank tread material is glued to the outside of the wheels?
thanks
Unread 11-01-2003, 22:22
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
It's illegal to modify wheels by adding material to the outside.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 11-01-2003, 22:23
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
errrr I know what your thinking of and it isn't illegal. You can' t glue the treads onto the wheels. You'd have to use pulleys and then have the belts wraped around it. Glueing it wouldn't work
Unread 11-01-2003, 22:37
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Tank Treads
Definatelly treads, but, dont waste your time trying if youve never done it before, its expensive, and difficult to do.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 11-01-2003, 22:50
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Please elucidate yourself better.
It is illegal to add material to the outside of purchased wheels.
If you manufacture your own wheels, you may add material to the outside.
--Madison--
...down at the Ozdust!
Unread 12-01-2003, 00:23
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
If that is true, was it true last year?
Cause we bought skyway wheels (actually the same ones that came with the kit this year) and we screwed more grippy rubber belt onto them. We had no problems with any rules of "not adding things to the outside of purchased wheels".
...and I don't recall ever reading a rule that said anything like that.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 12-01-2003, 00:41
srjjs's Avatar
AKA: Larry Wang
Yeah, that's what I meant. If you made your own wheels, how could it be determined whether the protrusions were "added" or part of the "original" wheel? The only time FIRST has a baseline to compare with is when you have purchased your wheels from an outside source.
SVR Imagery Award
RIP Andrew Dang
3/22/2004
Unread 12-01-2003, 00:50
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
its a new rule, to encourage you to make your own wheels this year. we've always done it in the past since 2000, and its really worth it to take the extra 3 days and make wheels. many of you probably remember our chromed wheels last year, took us about 3 days to complete the whole thing
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 12-01-2003, 02:01
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Wheels are by far easier, especially now with the pre-fab gearboxes. Tank treads are not always as advantageous as they may seem. I've been on a team that used them before, it worked, it worked at a moderate speed, but it ate power like nothing else.
In a situation of a steep grade or changing terrain, a well distributed force can also act somewhat as a suspension. 2 years ago, most of the treaded robots were designed to go over the 2 x 6" platform under the bar. This was advantageous because even when the bot was begining to balance it's weight on that beam, it still had lateral force against the beam.
My personal belief for this game is that wheels are more effective than treads, a 14º grade is not too steep where treads are required and there are no obstacles to climb over.
The most power can be gained from wheels while the most traction can be gained from treads. A high-traction system will mostly only need in place when fighting for king of the hill.
The big difference between wheels and treads, the Friction does not change but Traction does. Friction doesn't care about surface area, as per nominal equations. Traction however increases as more points of a friction surface are engaged.
The big downside that I see against it for this type of competition is the forces that go into it. I'm no engineer but this is what I assume from what i've seen..
in black, surfaces that contact the ground/belt
in grey, round surface that interacts with ground/belt
in red, my opinion of how motor power is distributed.
Also note the number of moving parts. More moving parts = higher chance for failure.
Unread 13-01-2003, 13:38
Martin Martin is offline
#0907 (East York Cybernetics Core)
Martin is an unknown quantity at this point
Send a message via ICQ to Martin
you cannot add material to teh wheel outside ? can u subtract material ?
or does the rule state...simply "no modification" ?
even with the 1" crappy skyway wheels, its possible to cut otu a good design on them, for traction.....
2002 - 3rd seed
2002 - highest rookie seed award
2002 - J&J sportmanship award
Martin
907
Unread 16-01-2003, 22:45
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
new rule
PAGE 20, RULE M17
This rule was drafted to attempt to prevent damage to our playing field, which includes the
ramp structure, field borders, etc. Because we allow you to fabricate a wheel, it really doesn’t
make much sense for us to say:
“The outer surface of off-the-shelf wheels may be modified by removing tread material only.”
Please delete this sentence; however, now we need to address the issue of “anti-traction”
devices or anchors, i.e., devices designed to hold you firmly in one place. Anchors cannot
use metal in contact with the carpet to “stay put.” Similarly, metal traction or anchor surfaces
are not allowed on the ramp surfaces.
Add the following to Rule M17:
Anchors, i.e., devices that are deployed/used to attempt to keep one’s robot in one place and
to prevent from being moved by another robot, cannot use metal in contact with the carpet to
“stay put.” Similarly, metal traction or anchor surfaces are not allowed on the ramp or
platform.
so now you can add stuff to you wheels, or take it off, it's your pick.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 17-01-2003, 20:59
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
basically, all that first really wants (same thing last year, and i believe the years before) is that the robots aren't made in a way that messes up the rugs and stuff, cause then its bad for everyone who plays after... the refs normally won't bother you unless your tread is made of metal chain links or your wheel has hooks or pointy things
Trust, Love, and Magic
Unread 17-01-2003, 22:25
Gadget470's Avatar
A Fire Outside
Do any engineers have any rebutals to my post earlier? (With the picture of Wheels vs Treads). Because if I'm wrong on why treads are generally slower, I would like to know the real reason
Unread 20-01-2003, 23:01
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Here's my take on it:
Treads can provide more traction, but don't always.
Treads are a tricky thing to do right. (I've seen many a good throw off a tread in a match) In fact team 68 abandoned them alltogether midseason in 2001.
Treaded machines usually move slower because the differential torque required to steer them is very high (it's also pretty big for 4 wheel skid steers).
My prediction: Well designed treaded machines will dominate the ramp scene, while higly mobile wheeled machines will dominate the stacks. Oh wait really fast wheeled machines with suction cups might dominate the ramp, assuming they get there first.
Unread 24-01-2003, 00:30
make me care
#0555
Team Role: Student
but my team, a basically rookie team, had perfectly working treads last year, our problem was with bad bearings (they popped out whenever a robot hit us, and half the time when we hit a goal) and with gearing... for some reason no one, not any of our engineers (who we love) nor our teachers (mostly physics teachers too) could help us figure out the right gear ratio for the drive train - ended up being the fastest the chip motors could put out, provided the robot weighted nothing...
on topic: the treads normally take a little extra work, but if done right, can be hell on wheels, (i mean treads).
wheels are easier, but normally have less traction
bottom line ? either works, just get something with moderate traction and ok speed, and then tinker until its good, because as long as the robots well designed (over all), an ok drive train will still murder (i mean beat in a friendly manner) most other teams
Wheels or Treads redbeard0531 Technical Discussion 21 13-01-2003 21:05
Tank treads and specialty wheels archiver 2001 7 24-06-2002 01:25
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
TANK TREADS...welp. archiver 2001 13 23-06-2002 22:50
