Go to Post My driving skills are only slightly better than my dancing skills... - RoboMom [more]
Unread 14-12-2012, 08:18
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Re: Incorporating the vex ball shifter into a WCD Drive
We will post a rough draft of our "Vexpro WCD" before the end of the weekend, and maybe follow up with a more refined setup before ship.
We are also heavily tempted by the WCP gearboxes. They are an iteration of our custom gearbox design, so they'd likely be a good fit into our designs.
I CANNOT WAIT TO SEE THIS.
We are thinking about doing this with belts and just using the 1x3 as the mount plate for the third stage with larger standoffs. Which would allow for the pulleys to be contained in the 3rd stage of the gearbox.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRSTŪ or my affiliated team.[/center]
FRCŪ Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 14-12-2012, 12:54
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
I made this yesterday, but I think we might be pursuing a different option at this time.
The ratio on this is
12:50 1st Stage - CIMs
14:50 1st Stage - Versaplanet 4:1 (I like just putting it in on the plate just to have the option.)
50:44 High
34:60 Low
30:40 3rd Stage
Edit: Probably should have added another view to be more descriptive.
ID:	13282  Click image for larger version
ID:	13283  Click image for larger version
James Tonthat
Mechanical Engineer, RackSolutions
Texas Torque - 2009-2014
Robowranglers - 2015-
Unread 14-12-2012, 13:16
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I'm picturing a wider custom version of the 3rd stage add-on that Vex sells. Put your two sprockets inside and change the 3rd stage ratio to be appropriate for direct drive. Sounds like a fun winter break project.
Unread 14-12-2012, 15:01
Brian Selle's Avatar
Brian Selle Brian Selle is online now
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
If you are able to remove the hex output shaft pressed into the ball shifter shaft and replace it with your own, you could just add some pulleys/sprockets and a couple standoffs like the attached picture. The picture shown has 30 tooth pulleys and the clearance with the 4 standoffs is close... to get more clearance with smaller pulleys/sprockets you could rotate the entire gearbox slightly about the output shaft and use the 2 standoffs in the upper left/lower right corners (2nd picture). Would be good to work in some more support for the cantilevered gearbox.
Unread 14-12-2012, 15:14
FRC #1836 (MilkenKnights)
Attachment 13286
Attachment 13288
If I remember correctly, the output speed of the ball shifters without the third stage is a bit too fast to direct drive.
Unread 16-12-2012, 14:17
AdamHeard's Avatar
Lead Mentor
Posted CAD of the implementation here.
This is a real rough model showing our concept for mounting the ballshifter only, it's a bit clunky now and if we ran with this we'd likely refine the mount a bit more.
Don't interpret this as a specific decision by 973 to do 8wd with that spacing, those wheels, etc... but rather focus on the ball shifter interface, and that we're switching to 1/2" hex all around in hex bearings.
Hopefully this helps a few people.
Unread 16-12-2012, 14:41
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Unhappy Re: Incorporating the vex ball shifter into a WCD Drive
Adam, unfortunately my cad is not working could you add a picture or rendering of what y'all have come up with? Also... I see Hodgepodge and Viper, what are those? Again my Solidworks isn't working so I can not see these models.
P.S. I didn't mean to put that purple smiley next to the post... and I don't know how to take it off.
Unread 16-12-2012, 14:42
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Adam,
Can you post a screen shot or two?
"A genius is just a talented person who does his homework" T. Edison
Unread 16-12-2012, 14:45
AdamHeard's Avatar
Lead Mentor
Sheesh, nobody is ever satisfied
Here is an iso with the frame supressed, and then with the mount plate made transparent.
ID:	13307  Click image for larger version
Name:	iso clear.JPG
Unread 16-12-2012, 15:41
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Thanks for the pic. thats essentially what we do with supershifters, but this got me past a mental block I had with implementing the 3 stage ball shifter.
Unread 16-12-2012, 15:43
AdamHeard's Avatar
Lead Mentor
Yup! Trivially different from what we did w/ SSers in 09.
The biggest pain was how to cleanly attach to the face of the ballshifter w/ the extra standoff we had.
It's clear in CAD, but not in the pic. The lower hex standoff doesn't attach to the ballshifter, but rather to that .25" thick plate with a hidden flathead 1/4-20. The plate then attaches to all 3 ballshifter mount holes and is a large bearing surface on the face. This should really adequately handle the moment reaction.
Since we don't have one on hand, we were unsure of the strength of that face. We assumed that since IFI put in hex bores for standoffs, that small local face contact for moment reaction would cause damage. So right now we're assuming we need that large plate to touch so much.
Unread 16-12-2012, 17:00
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Thanks for posting the pics. (It's great to be able see what you're talking about without downloading it and waiting for SolidWorks to load.)
Is that plate supposed to be flush with the 2x1 tubing? If so, there's going to be some interference between those two button head screws and the tubing wall. Also, how would you plan to remove the gearboxes in competition?
-Plutarch
Unread 16-12-2012, 17:02
AdamHeard's Avatar
Lead Mentor
The CAD is very clear here. The plate is flush, the bolts go through the tube, through the plate, into the tapped standoff.
We remove the bearing block faceplate, remove the two 1/4-20 buttonhead, and the gearbox is removed. Identical in function to our current designs. We consider the bearing block an integral part of the gearbox.
None of this is untested, all we did was make the ballshifter the same black box more or less as our current designs.
Unread 16-12-2012, 17:11
AKA: Joe Barry
I'm satisfied now
Unread 17-12-2012, 03:31
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
Are you looking at using belts or are you thinking strictly chain-drive?
