Go to Post Cut it out with the paper airplanes! Frank hath spoken! - cgmv123 [more]
Unread 16-12-2012, 16:52
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Step by Step Hole Reaming Instructions
In order to machine our own gearbox side plates or chassis rails, we're going to need to ream some 1.125" and .875" bearing holes. We can do this in house, vs having to go out of house to CNC machine.
What is the sequence of events that takes place en route to reaming the hole? In particular, how many intermediate drill sizes are we going to need? Currently we don't own any drills larger than 1/2", so in order to ream holes we're looking at investing in both a reamer and the intermediate drills that will be necessary. What size would you drill the final hole before reaming? Would you recommend a 1.125" and .875" reamer, or something slightly undersized? The bearings will either be pressing into a sideplate (3/16 or 1/4) or a nano-tube style chassis rail/gearbox of 1/8" wall, 6061 or 6063 aluminum.
Thanks.
Unread 16-12-2012, 17:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Step by Step Hole Reaming Instructions
I'd recommend a drill that's 1/64th under, and when you run the reamer, go slow RPM. To get a press fit, you'll need a reamer that's about a half-thou under size. Or, don't rely on press fits.
One trouble you'll have is finding reamers in those sizes with a 1/2" shank.
You might also consider looking into TCT hole cutters in those sizes.
Unread 16-12-2012, 17:07
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I've heard that it can be quite a pain to machine 6063, so watch out for that. I know that some tubing sizes are really hard to get in 6061, but, well, watch out.
If you can't dependably do press fits, then design around it. Make sure that all bearings are retained from both sides by either their flanges or snap rings/shaft collars. All the press fit is doing in this case is making sure the bearings don't fall out.
-Plutarch
Unread 16-12-2012, 17:11
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
What I did when cutting 1.125 bearing holes in 1/8 wall box beam. Started with quarter, then straight up to 1 inch, the largest drill we have. The pilot should be just big enough for the center part of the 1" drill which is not center cutting. Then I bored the hole to just under, and reamed it by hand to the final size.
Unread 16-12-2012, 17:13
craigboez's Avatar
Mechanical Engineer
To this point we haven't needed to rely on a press fit for bearing retention. We can design in flanges on the bearings, spacers, e-clips, etc to keep the bearings in place.
Unread 16-12-2012, 17:16
craigboez's Avatar
Mechanical Engineer
I don't have any experience with these. Do they hold tolerances well enough for this application?
Unread 16-12-2012, 17:19
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
I'm looking to doing the same, machining 1-1/8 inch holes to a tight tolerance. I've been looking in to either a "sheet metal cutter" which can do 1/4" (e.g. http://www.trick-tools.com/Sheet_Metal_Cutters_81) or an annular cutter with a weldon shank adapter for our R8 mill.
I'd like to know if anyone with machining experience could comment on the above?
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 16-12-2012, 17:36
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Out of curiosity, why did you ream the hole if you were already boring it? Boring should have given you superior dimensional accuracy.
Neither of those is going to give you a press fit. Possibly not even a very close hole to what you want.
The only good ways to get a dimensionally accurate hole to tight tolerances with manual equipment are reaming and boring. Boring is better as it will give you both a straight and dimensionally/positionally accurate hole while reaming will follow the existing hole. If it's not straight, or on location, your reamed hole won't be either.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-12-2012, 17:58
craigboez's Avatar
Mechanical Engineer
We don't own any boring equipment. Any specific recommendations on what we would need?
Unread 16-12-2012, 18:21
Cory's Avatar
AKA: Cory McBride
You're going to need a mill and a boring head (top left). You could run a boring head in a drill press, but you'd have no way of accurately locating the hole in the part. I suppose a drill press with x-y table would work. I would much rather use a reamer or some other means-boring is a much more involved process that is going to take awhile to setup and run.
It's possible you could use an annular cutter or a hole saw if you were willing to live with a loose bearing fit. The annular cutter is probably going to do a better job. You could also buy an end mill in the size you want, which would do a pretty good job. That would run you about 60 bucks for a 1.125".
2001-2004: Team 100
Unread 16-12-2012, 18:28
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I've always known we had boring tools for the mill, but have only ever used a boring bar in the lathe. Is the procedure to set the boring bar to the appropriate radius above the part, and then cut, or to somehow adjust it while in the part? I ask because on the lathe, I often adjust the radius of the cut while inside the part (so long as the part isn't too thick).
-Plutarch
Unread 16-12-2012, 18:40
Cory's Avatar
AKA: Cory McBride
I don't know what a machinist would tell you, or an instructor if you took a class, but the way I've always done it is to visually adjust the boring head above the part so that you'll take a small cut. Make that cut and then measure the diameter of the hole. Once you know the diameter of the hole you know how much you need to adjust the boring head. Odds are that unless you need to remove a very small amount, you can't go immediately to this number, but you at least know your starting point. In a production environment I'm guessing you would have some kind of offline fixture that would allow you to adjust the boring head to the right dimension with no trial and error.
If I'm understanding your question correctly you're asking if you can change the cutting diameter of the boring head without retracting it from the hole?
To adjust the cut diameter you have to turn a screw that is mounted radially on the body. The machine has to be stopped to do this, but if you're inside the hole and you try to increase the cut diameter you will push the boring head against the wall of the hole (see below).
You could do it in the hole if you moved one axis of the machine away from the hole, but you will still have to retract the tool from the hole and come back to the zero position to re-start your cut . This is common on CNC mills, so that they can retract the boring bar from the bore without scraping the wall.
2001-2004: Team 100
Unread 16-12-2012, 18:50
Joey Milia's Avatar
FRC #0192 (GRT)
I reamed the hole because the boring head we have isn't very good, it's metric and has a lot of backlash in the adjustment screw so I wasn't comfortable trying to get the exact size without going over.
Unread 17-12-2012, 01:45
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Using a drill press to get a located hole I suppose one could use a height gage to scribe a x y on to the piece. Then use a center punch and a center drill to get a good start on the hole. Then I would take a .257 drill bit to drill a pilot hole. Once you got the pilot hole one would use a ground c'bore to the press fit size for the bearing with a .250 pilot to guide the cbore.
See this link to see what I'm talking about.
http://en.wikipedia.org/wiki/Counterbore
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 17-12-2012, 01:53
Lowes sells Ideal brand hole cutters in 7/8 and 1 1/8 sizes. We have the 7/8 one we use on occasion for prototypes. It works well. I don't recall the exact hole size it comes out with, but in a drill press I recall it being .005 bigger or less. It would be better in a mill. It makes a nice clean round hole that works fine with flanged bearings.
