Go to Post Probably planning on milling the bumpers out of solid pool noodle stock, too. Ever wonder how they drill that hole down the middle of pool noodles? ;) - Bill_B [more]
View Poll Results: What is your autonomous mode strategy?
Line-tracking 23 38.98%
Dead-reckoning 37 62.71%
Seek-Enemy-Stack-and-KILL!!! 14 23.73%
Other - please list. 15 25.42%
Multiple Choice Poll. Voters: 59. You may not vote on this poll
Unread 16-01-2003, 23:43
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: Dead reconing
Originally posted by bigqueue
When people say dead-reconing, are they talking about simple "timing" of moves and turns, or are you talking about having wheel encoders and such.
Big difference....
Dead Reckoning is ANY method to keep track of your position that uses INTERNAL knowledge of where you started plus knowledge of your actions instead of an EXTERNAL location reference source.
This can be accomplished by watching wheel revolutions, integrating each motor's speed over time, watching an internal "inertial guidance reference" brick, etc... And yes, this IS a programming problem!
ALL Dead Reckoning systems have drift problems over long distances, long times, or number of moves. Errors accumulate. The advantage is low cost.
The question boils down to "is it good ENOUGH for what I want to do"? Over short distances, times, and moves, Dead Reckoning is pretty good. But cruise the arena long enough, spin your tires once, be shifted by hitting an opponent, wall, or unexpected object, wait too long and your reference drifts, or add up too long a list and your resolution errors accumulate, and you no longer have a CLUE as to where you are.
BTW, as a piece of trivia, "Dead Reckoning" actually evolved from the homonym "Ded. Reckoning", which in turn was the abbreviation of "Deductive Reckoning". Deductive Reckoning is the ORIGINAL term for the method of "deductively computing" where your sailing ship at sea was at when you couldn't see the stars as an external reference. You'd use your compass, and every so often toss out a knotted rope and counted "knots" unreeled to a timepiece. That gave you your heading and speed. (Hence the nautical term for speed is in "knots"...) You integrated it in your logbook over time to estimate your position, until you could see stars or sun again. The spelling simply mutated over time from people hearing sailors speaking the abbreviation.
Some day, I think it would be GREAT if FIRST put coded retroreflectors in the corners of the field and we had enough parts and CPU crunch to have an EXTERNAL navigation reference for the autonomous phase!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
