Go to Post All battery terminals must be wrapped in tape or other insulating material AT ALL TIMES! - Al Skierkiewicz [more]
Unread 17-12-2012, 07:56
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: pic: New to CADing for FRC. Critique? Would this work?
Akash beat me to the punch.
He hit the highlights well, but that lightenging pattern will definitely not work.
It doesn't look like there is any thought in the layout as to structure or function, it just appears to be there to remove weight. The pattern should have web stretching between all bolt/bearing/spacer holes to give strength where the loads are.
Thank-you 294 & 67
www.bobcatrobotics.org
