Re: pic: New to CADing for FRC. Critique? Would this work?
Increase the diameter of the standoffs that hold the sides together. Doing so will distribute the shock load better and also provide more surface area to help stiffen the side plates when your assembly is tighten. If you added a bend along the leading edge that would help and you could add some brackets between the side plates to keep the plates parallel and square
