Go to Post When I had "shop" back in High School they emphazied safety to the fullest extreme. I'm glad they did, I still have a full set of 7 fingers........ - Stillen [more]
Unread 17-12-2012, 17:11
jacob9706 jacob9706 is offline
AKA: Jacob Ebey
FRC #3574 (High Tekerz)
jacob9706 is on a distinguished road
Cool New autonomous outline tutorial
Hi everyone,
Today I will be showing you how to implement an easy autonomous system based on callbacks/events. If anyone has done JavaScript using the jQuery library you will be quite familiar with the concept of a callback. A callback is a function (or method depending on the language) that executes after a set of code is done running.
Here is a quick jQuery example...
$(document).load(loadFunction);
var loadFunction = function() {
	alert(“Loaded”);
What we will be doing today will be a little bit different. We will be creating a “list” of actions we want to preform one after another. This list will be represented as a vector of functions. The first thing we have to do is define a function pointer that returns a boolean and has nothing as its paramaters.
typedef bool (Event*)(void);
That line defines a function pointer called Event that takes nothing(void) and returns a boolean(bool).
The next step will be to define a function that will execute all of our function pointers called Event.
// Function that takes a vector of Even
bool runStringOfEvents(std::vector<Event> events)
	// Loop through every event
	for (unsigned int i = 0 i < events.size(); i++)
		// Get current event from vector
		Event event = events.at(i);
		// Execute the event and get the return value
		bool success = event();
		// If it failed return false
		if (!success)
			return false;
	// If all succeeded return true
	return true;
Now that the hard part is done we can create a function we will call two times through a list of events we pass to our runStringOfEvents function.
bool someEvent()
	std::cout << “Event executed” << std::endl;
	return true;
Now that we have our event function we can create a list in our program and execute the list of events.
int main(int argc, char** argv)
	// Create the vector to hold our events
	std::vector<Event> events;
	// Add the function to the list twice
	events.push_back(&someEvent);
	// Run the events
	runStringOfEvens(events);
* Team 3574 Alumni
* 2011 - Highest Seeded Rookie
* 2011 - Rookie All-Star
* 2012 - Engineering Inspiration
* 2012 - Olympic Deans List Winner
* 2013 - Engineering Inspiration
* 2013 - Judges Award (For unique circular robot and the way the team works together.)
Unread 17-12-2012, 23:26
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: New autonomous outline tutorial
Maybe I'm completely missing the point, but why not just call the commands in a list, procedurally? Like, if you had functions drive_straight(float dist, float speed) and fire_ball(void) you could just do
void autonomous_1()
drive_straight(10,30);
fire_ball();
wait(500);
fire_ball();
drive_straight(-10,30);
And you would make more functions for more autonomous modes. It seems like a more elegant and execution-efficient solution.
I'm not saying there aren't reasons for storing commands in a list. In fact, I myself wrote a system which is by all metrics complex in LabVIEW to do a similar thing. However, I was trying to gain the ability to store the command vector in a text file, and load it on demand. Had I only wanted to write the commands in LabVIEW, I would have just called the command blocks in sequence (which I did successfully in our 2010 season, which suffered only from a very long on-field iteration time due to LV compile time issues).
Kettering Motorsports
Unread 18-12-2012, 00:14
AKA: Jacob Ebey
void autonomous_1()
fire_ball();
wait(500);
fire_ball();
The reason for this is to be able to spawn them in separate threads... I originally wrote this today just for fun.
* Team 3574 Alumni
Unread 18-12-2012, 00:47
apalrd's Avatar
More Torque!
VRC #3333
I see. You are able to launch the next command before the previous command finishes.
That makes a lot of sense. However, when do you really need to do that? I spent a very long time trying to get my script system to allow asynchronous command execution and decided that it was too difficult of a tradeoff in code complexity. I found that there was no reasonable case in which it was impossible to write autonomous code with only one autonomous commanded action executing at a time, with the blocks I wanted to write.
The tradeoff is always between simplicity in execution and flexibility in design.
Unread 18-12-2012, 02:35
AKA: Jacob Ebey
The other reason I would do something like this(Which I have not yet been able to try) is to allow errors. As you see if one of the functions returns false the rest do not execute.
* Team 3574 Alumni
Unread 18-12-2012, 11:40
Have you looked at the Command based programming model introduced in 2012?
Unread 18-12-2012, 14:31
AKA: Jacob Ebey
No I have not. Where could this be found?
* Team 3574 Alumni
Unread 18-12-2012, 15:01
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
The 2012 WPILib Cookbook explains how it works. Read the whole document first but CommandGroups described on page 50 may be of interest.
http://firstforge.wpi.edu/sf/docman/...tation/doc1297
Unread 18-12-2012, 15:23
http://www.chiefdelphi.com/forums/sh...79&postcount=7
http://www.chiefdelphi.com/forums/sh...88&postcount=1
http://www.chiefdelphi.com/forums/sh...d.php?t=109719
http://www.chiefdelphi.com/forums/sh...1&postcount=25
